question
Old Jun 26, 2010 | 07:11 AM
Patrickb1513's Avatar
Default question
have a 99 gst AUTO how much would it be to convert to a manual?and is there any shops u guys can reffer me to,thanx for your time
Old Jun 26, 2010 | 07:38 AM
IllegalModz's Avatar
Hello well the real question is how much does everything cost to do it,5 speed transmission with all mounts sensors and everything associated to the transmission, axles, slave and master cylinder, linkage cables complete shifter assembly, center console to change from auto, complete wiring harness for a 5 speed that's if you really want it done correctly,ecu, 5 speed cluster, complete clutch, flywheel and peddle assembly. I might be leaving out something. How professionally do you want it done? Ive seen people not change the harness and cluster and other stuff buts its just a hack job. I have a donor car, that's what you need a car with everything in it. Or you will be looking all over the place trying to find hard to find things. We can also furnish and install the complete conversion. If you are interested please share a private PM or simply call the number below good luck and thanks
WWW.ILLEGALMODZ.COM
SERVICING ALL MAKES AND MODELS
MAIN ST DUNEDIN
18887651500
AUTOMODZ
ILLEGALMODZ@EARTHLINK.NET
AUTO (AUTO MODZ) | MYSPACE
* $50 PER HR IS OUR RATE
*(STANDARD JOB PRICES)
ENGINE REBUILDS STARTING @ $600 PULLING AND INSTALLING EXTRA, WARRANTIES ARE AVAILABLE
MOTOR REPLACEMENT STARTING @ $500
TRANSMISSION REPLACEMENT STARTING @ $500
CLUTCH REPLACEMENT STARTING @ $300
TIMING BELTS/WATER PUMPS STARTING @ $250
TURBO UPGRADES STARTING @ $250
Old Jun 26, 2010 | 11:44 AM
pure_kustoms's Avatar
"Non Silba Sed Anthar"
^ good info and prices!
where are you located? i have a couple cars as well i am parting out.
Old Jun 26, 2010 | 03:22 PM
x8psycho8x's Avatar
from what i heard about tranny swapping a gst (from auto to manual) is that it's basically a bitch and you should sell and buy a manual gst. but thats what i've heard.
on a side note tho, depending where you wanna take the car you should just keep it auto, even tho manual is more fun (in my opinion)
94 accord vtec - traded
95 eclipse gs - blew up
95 eclipse rs - dd
Originally Posted by SayWhaa?
guess some of the guys shes sleeping with isnt too good with the whole pull out method..
Originally Posted by evlonedb
someone needs to tell her its a vagina,not a clown car!
Old Jun 26, 2010 | 03:25 PM
HeLzKaos's Avatar
its pretty much the same just gotta tweak a few things nothing major. just like doing a n/a auto to a man
Old Jun 26, 2010 | 03:31 PM
TrboANTsi's Avatar
FL,..gods waiting room!!
keep it auto ...
Old Jun 26, 2010 | 03:33 PM
wishiwasfast's Avatar
Lightbulb
Originally Posted by TrboANTsi
keep it auto ...
+1. they are stronger than manuals too.
Old Jun 26, 2010 | 03:36 PM
chillllll's Avatar
11 second club
make it a gsx and keep the auto
10 sec street truck...
Old Jun 26, 2010 | 03:39 PM
HeLzKaos's Avatar
u do what u wanna do every one has diffrent opinions. good luck with what u decide
