ecu reset question
Old Jun 5, 2002 | 06:50 PM
PiercedJD's Avatar
sometimes they are tempremental and take a while to learn everything that's on the car again........ can take from a couple hours, to a week or so, depending on how often you are driving the car....... have you tried a sustained drive on the freeway? like 30 minutes above 60 or something like that?
Old Jun 6, 2002 | 09:48 AM
highoctane's Avatar
James, I've passed the emissions tests here in FL with my old f-body without evening having a cat on it with all the normal bolt on's, it passed with a little room to spare.
With a big cam, long tube headers, no smog pump, no EGR, nothing but a cat I still passed emissions.
Reseting the ECU shouldn't effect emissions by any margin that would cause you to pass or fail, especially with stock cams, the ECU will quickly make the proper corrections to the AFR from O2 sensor feedback to maintain a stoich/14.7:1 AFR, if you didn't pass there has got to be a problem somewhere else.
What part of the test did you fail?
Old Jun 6, 2002 | 08:07 PM
PiercedJD's Avatar
come back to florida and renew here..... just tell the people in georgia you are on a long vacation. probably be cheaper than paying them to pass emissions anyway. or grease the guys palms and have him roll a bone stock 2G eclipse onto the machine.
Old Jun 10, 2002 | 06:20 AM
highoctane's Avatar
There should be a vacuum diagram of the emissions systems on a decal somewhere on your hood.
If they are plugging into the ECU to see whats going on you may need to get an O2 simulator for the 2nd O2 sensor if you don't have a functioning cat, the cats operational state is determined from feed back from the 2nd O2 sensor, I believe its suppose to give something like a constant .4-.5 volts when operating correctly.
