Mitsubishi Eclipse Check Engine Code
Old Nov 19, 2009 | 11:06 AM
phpryan's Avatar
Default Mitsubishi Eclipse Check Engine Code
I was driving today and I had a check engine light come on, I hooked up my AutoTap and it said the following codes
1.) P0301 Cylinder #1 Misfire
2.) P0400 Exhaust Gas Recirculation Flow Malfunction
How would I go about taking the EGR System out or bypassing this?
Old Nov 19, 2009 | 05:11 PM
EvoJeyMorrisMTRSPRTS's Avatar
Mitsu Evo and Subaru GURU
Ohh god who hates the egr system lol. The egr is picking up the cylinder misfire. Check your plugs first in cylinder 1. make sure your connections from your wires are good. Then go from there bro.
Morris Motorsports
Clearwater Fl
727.560.0512 call/text
Old Nov 19, 2009 | 07:19 PM
phpryan's Avatar
Checked the wires, they are all good. Could it be that the EGR dumped too much exhaust into the cylinder and caused it to misfire?
Old Nov 20, 2009 | 06:11 AM
it could be but not likely. R u not in florida anymore? I could look at it. Did u check the plugs?
R u using stock ignition setup?
Morris Motorsports
Clearwater Fl
Old Nov 20, 2009 | 07:19 PM
phpryan's Avatar
Yes its a stock ignition setup, no I am in Las Vegas now I moved bro.
