reading wide band with external wastegate?
Old Oct 12, 2009 | 06:13 PM
toyotiny's Avatar
Default reading wide band with external wastegate?
ok so i was thinking about somthing the other day i did a search but dident come up with much so hear it goes. ex-so if im driving around eyeballing a real deal wideband say lm-1 or uego not a discount cheap-o! alas i reach max boost whatever it might be and my external waste gate which is dumping into the out side world!opens up! so the question at hand is, is my wideband still reading correctly or should i be compensating for the fact that im leaking out exhaust ?
THE WING MAN NEVER LETS YOU DOWN!
Old Oct 12, 2009 | 09:06 PM
John's Avatar
lol @ tampa
you're overthinking this. Why would your wideband be off? Its only going to dump exhaust out, not change the ratio which is reaching the sensor
2008 AW 335xi coupe - Dinan stage 2 - DCI - Dinan axle back
|Full color business cards||flyers||postcards||more|
Old Oct 13, 2009 | 08:36 AM
omgosh's Avatar
Its not like an exhaust leak because the wastegate wont be drawing in outside air like a hole in the exhaust pipe would, just blasting it out. Thats what I would think anyway.
Old Oct 13, 2009 | 08:53 AM
Needfstwheelz's Avatar
^ HIGH...My Name Is
couldnt be explained any better....(someone will be sure to post a 3 paragraph thread on why im wrong any minute now...)
97 Mitsubishi Eclipse GST
95 Honda Civic ex coupe
95 Eagle Talon ESI
92 Mitsubishi Eclipse GSX
90 Acura Integra LS
94 Honda Civic ex coupe
90 Honda Civic std hatch
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
92 Acura Integra Gs-R
Old Oct 13, 2009 | 12:26 PM
toyotiny's Avatar
thanks gents its what i thought at first but it made to much sence to me right off the bat so i figured i must be wrong! i wasent sure if say i was rich and fuel is heavyer then air would it tend to leave the wastegate, which depending on wastegate position and location might be a path of least restriction there for giving me a leaner reading than it should. but your probably right and im over thinking it. thanks again guys.
Old Oct 13, 2009 | 09:31 PM
dsm_gst's Avatar
+1, plus its reading the oxygen content within the exhaust not pressure or pressure differences.
Originally Posted by LSrex
what do you tell a bitch with 2 black eyes....
Originally Posted by markzeronine
Nothing, you told her twice.
Old Oct 14, 2009 | 11:13 AM
BOX SENTRA's Avatar
OG MUDBONE 240sx
the o2 mixture is evenly mixed throughout all of the exhaust gasses, you can dump out all you want and it will still get the same reading because its a ratio of air compared to burnt fuel. (whatever fuel gets dumped out, the same of air is going out with it, keeping the ratio the same.) kinda like a glass of sugar water mixed evenly, theres still the same amount of sugar compared to water no matter how much you dump out.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Oct 14, 2009 | 01:42 PM
toyotiny's Avatar
thanks guys just wanted to make sure i wasent missing or missunderstanding anything.
