SAFC wires
Old May 22, 2009 | 05:02 AM
howeeez's Avatar
howie
Default SAFC wires
My current safc is acting silly. The reason is that the orange wire coming out from the clip to the safc, is keep coming undone. i have already suddered the wire and since its so damn thin it falls apart every so often. so now the wire has got so close to the clip where theres no room to actually splice it. I tryed rigging it by attaching another wire to both ends of the orange wire but it only worked for a week . My karman is off the wall at idle going from 4,17,8,23,16,9,13,4, you get the picture. So idle is rough and car stalls after a few min from rpm being so low. So my question is- Is there any shop around here that can actually cut all the wires out of the clip and re-insert them back in the clip? or am i screwed and need a new afc?
Old May 22, 2009 | 10:46 AM
lancerman's Avatar
you can eliminate the clip and solder wires directly.
or if you can figure out how to get pins out of clip you could swap an unused wire into the orange wire spot.
my favorite quote
Old May 22, 2009 | 04:40 PM
howeeez's Avatar
howie
I like the 2nd idea, but idk how in the world to get the pin out and insert the wire into the clip. lol my luck i would end up breaking something else lol. so I might have to go to the 1st idea and cut the clips off and just soder it. unless somebody on tr knows how to take the pin out and re insert another wire? Thanks
Old May 25, 2009 | 06:45 AM
howeeez's Avatar
howie
Update, Sodered the wires. Ghetto as hell. lol but it worked. thanks
