99 eclipse Clutch Bleeding ????
Old Feb 11, 2009 | 09:51 AM
BABYBOY8782's Avatar
BABYBOY
Default 99 eclipse Clutch Bleeding ????
I just got the car and the clutch pedal was real soft and engaged right of the floor sometimes a little when it was on the floor.. Tried to bleed it today and it wont get any pressure back.. slave cylinder or master?? Someone help so i know what to buy.. thanks
Old Feb 11, 2009 | 10:14 AM
blackFLgst's Avatar
Probably $#%#ing broke.
probably slave, but its better to do them both at the same time
REDLEG
13F
2010 Evo X GSR
Mods: 11's
Old Feb 11, 2009 | 10:20 AM
TrboANTsi's Avatar
FL,..gods waiting room!!
get under the car and pull back the rubber boot if theres fluid try changing that out first since its easy.
Old Feb 11, 2009 | 10:26 AM
BABYBOY
already pulled the boot off and it looks like its pretty dry. My fluid looks real dark think maybe line clogged? If so how would i clean it ?
Old Feb 11, 2009 | 10:59 AM
MightyMouse1's Avatar
You think your fast
take the restrictor out of the slave cylinder it is a black plactic pieace and a spring i gets cloged then bleed what i do is pump the clutch 3 times out the blleder valve depress the clutch hold then tighten the bleeder valve
