coilovers or lowing springs??
Old Feb 6, 2009 | 07:15 AM
dsmturbo84's Avatar
Question coilovers or lowing springs??
what is better coilovers or lowing springs?? i got some coilovers on my car and i was thinking of going to lowing springs, i had a 99 dodge neon and i put coilovers on it and not even a year later one of my struts gave out than i when to springs and the ride was better, but that was with a neon not a eclipse just asking people that would know, just to let you know i got a 96 gst spyder...
Old Feb 6, 2009 | 07:59 AM
John's Avatar
lol @ tampa
REAL coilovers, not stupid sleeve-overs, are your best bet
2008 AW 335xi coupe - Dinan stage 2 - DCI - Dinan axle back
|Full color business cards||flyers||postcards||more|
Old Feb 6, 2009 | 09:22 AM
Skip's Avatar
Throwback
It depends on what you like. I personally like Springs better. Springs are better for the street, they help to provide better traction on surfaces that are not perfectly flat. Springs have a much more comfortable ride than coilovers. They can keep your tire on the ground after a bump or change in uneven surface.
Coilovers are good for the track, and awesome for corners. They control chassis roll better and promote better steering response. JIC, Tein, Tokico, and Ground Control all make good setups (JIC Especially). These systems are expensive though. If you cheap out on coilovers, the only thing you will be satisfied with is your ride height.
When you choose a spring you have the option for a progressive wound spring or static rate spring. Progressive gives you more weight transfer and a better ride. Static rate is more like a coilover, you get better handling and less weight transfer, but a stiffer ride.
A FWD track car would want to go with coilovers. High stiffness in the rear and adjustable ride height helps to prevent the weight transfer and gives better traction for the launch. An AWD street racer can handle weight transfer a little better and benefits from a softer suspension due to the road, and should probably run springs.
Old Feb 11, 2009 | 04:51 PM
kanji1jz's Avatar
jza70r
Email me after you do your install. I have a zero clearance alignment lift so I can get ANY lowered vehicle on to my lift (unless scraping the ground)
89 jza70r
3" exhaust w/ apexi muffler
xs engineering intercooler
sportmax 962 17x9 (r) and 17x7.5 (f)
kelly charger hpt tires
eibach lowering springs
kyb struts
sneed speed shop dual electric fans
max steel solid engine and trans mounts
walbro 255 fuel pump
custom 2.75" intercooler piping
R.F.L. bov (not a big fan but it gets the job done for now)
