need fast help!!
Old Dec 12, 2008 | 05:26 PM
swenson13x's Avatar
Default need fast help!!
What is the stock psi that a 91 talon tsi turbo will put out and what is the highest and what is the lowest psi i can put it to?? and also can i adjust it on my turbo?
The reason i ask is im taking the stock turbo and putting it on my 07 skidoo 800r.
any help would be great. Thanks.
Old Dec 12, 2008 | 05:57 PM
EfWorld's Avatar
i run 16psi on my 99.. idk if they are the same. i have a tdo5
TR "Old Skool EF" Member #48
99 Mitsu Eclipse GS-T DD
91 Honda CRX Si
91 Honda Civic Si
91 Honda CIVIC Si FOR SALE da front brakes. mint interior, 650 buks
Old Dec 12, 2008 | 06:18 PM
Neesan's Avatar
EL RIPPO
stock is 10-11. If you run a line from the wastegate actuator to the nipple on the stock j pipe it will make about 8-9lbs.
< Forged internals with squirters stock. 14psi proof. It WILL be turbo'd, just not anytime soon.
Old Dec 12, 2008 | 06:22 PM
EfWorld's Avatar
you can always add a boost controler lol
91 Honda CRX Si
91 Honda Civic Si
Old Dec 12, 2008 | 06:37 PM
Neesan's Avatar
EL RIPPO
Forgot you asked how high you could turn it up. A 14b isnt gonna be very productive after 20psi, and thats with a HUGE fmic, I doubt youll have that on your jetski. So I would say 15-16 is as high as youd want to go, with a boost controller you wont be able to turn it any lower than the wasegate is set at which is around 8ish.
Old Dec 13, 2008 | 05:31 AM
Skip's Avatar
Throwback
Wastegate pressure is 8 psi for a 91.
Old Dec 27, 2008 | 12:47 PM
swenson13x's Avatar
thanks! and its going on a snowmobile not a jet ski but its the same concept. i just hope the sled can turn the turbo!
Old Dec 27, 2008 | 01:14 PM
slowy's Avatar
13.04@104mph
wouldnt a 95-99 turbo (t25)be easier to spool for a small motor?
or maybe a 1g automatic (13b/g) ?
