Eclipse has lost all power!
Old Oct 2, 2001 | 03:32 AM
TealTalon's Avatar
#1 the stock gauge means jack. It is not hooked up tp manifold pressure at all. It simply displays based on MAF counts. It sounds like you got a wicked boost leak.
#2 The old lifters tick...much like a bear shits in the woods its just something that happens. He can drop $100+ on the new revised lifters from the dealer if it bugs him.
Old Oct 2, 2001 | 09:09 AM
emodsm's Avatar
red ass
Originally posted by "Someone"
Originally posted by v8killer
Hey
The ticking in the valve train sounds a bit abnormal. I know you said the 1Gs tick but this is almost a banging rather than normal valvetrain noise. It sounds like a diesel powered Mercedes Benz!
Thanks for your help
banging noise? rod knock? does he have anythign done to the car?
also if its not reving check to make sure there are no leaks in the i/c piping. Also check to makwe sure the maf is pluged in it will cause a problem like that
eric.
Build your car for YOU, not for the fame and glory. Fame and glory fade with time but YOU will be around as long as you live.
Old Oct 5, 2001 | 10:16 AM
stangerang's Avatar
whoopdy fucking do!
Prolyl a stupid question but does the car free roll ok? Rty pushing it may be somethign as stupid as a stuck brake caliper..I have seen it happen.
200 points away from a 300
Old Oct 9, 2001 | 11:50 AM
dsm's Avatar
dsm
rice sleeper
i agree check to see if you have a leak. http://machv.com/ has them this where i got mine from or u can build your own.
2010 Evo X MR
12.3@110mph
344whp/375wtq
Jalvarez Studio
Blood_Sun
Jul 16, 2000 05:27 PM
