brake lights on 2G eclipse are staying on??
Old Aug 9, 2008 | 11:13 AM
GsEclipse02's Avatar
Default brake lights on 2G eclipse are staying on??
why??? any help thanks ....
Old Aug 9, 2008 | 11:43 AM
F4A22's Avatar
Old School
Moisture in the tailights are grounding the connections(usually will blow the fuse).Or your brakeswitch grommet is broken by the pedal.Answer 2 is more common.
Old Aug 9, 2008 | 11:53 AM
awdsal's Avatar
dsm fever
its most likely your brakeswitch gromet
Old Aug 9, 2008 | 12:00 PM
is this something that i can buy at autozone ???
Old Aug 9, 2008 | 04:00 PM
BoostLogik's Avatar
BoostAddict
Yeah, check to see if you have some broken plastic pieces on your floorboard. I had the same issue, and found my grommet broke. You can just take some metal washers, pennies, or other small round coins/metal objects and duct tape those bitches around the brake pedal lever. That's what I did and it's worked great since. A little tricky at first, trying to do it yourself...but not that bad.
If you lay down on the floorboard, you'll see where the grommet should be on the brake pedal lever. When the brake pedal lever is in it's neutral position, you'll see where it should be contacting the brake light switch (little black button thingy), towards the top of the brake pedal lever. Snugly tape down some coins/washers, etc. in that spot....then test it by pumping the pedal a few times, or take it out for a small spin.
Be sure to check on it for the next couple days as well, to make sure the tape holds up. As long as you have the tape wrapped tightly, you should be good to go. Just make sure the tape cures over the next few days and holds. Voila! Problem solved.
"Even through the darkest days, this fire burns, always"
Old Aug 9, 2008 | 04:54 PM
Originally Posted by BoostLogik
Yeah, check to see if you have some broken plastic pieces on your floorboard. I had the same issue, and found my grommet broke. You can just take some metal washers, .
this is what i did ...
thanks every one
Old Aug 9, 2008 | 06:02 PM
blackFLgst's Avatar
Probably $#%#ing broke.
I just took mine to the dealer and they said it was a recall. They fixed mine for free
REDLEG
13F
2010 Evo X GSR
Mods: 11's
Old Aug 10, 2008 | 08:23 PM
chillllll's Avatar
11 second club
take your foot off the brake?
10 sec street truck...
Old Aug 11, 2008 | 06:36 PM
98_GstEclipse's Avatar
My brakes were doing the same thing. I ended up just unplugging the harness and said fuck it. Pretty stupid tho since people dont know when im stopping. Its been like that for 2 months. I might try the penny thing 2morrow too. Yea I know Im a lazy fuck when it comes to small things
Old Aug 11, 2008 | 08:33 PM
chillllll's Avatar
11 second club
yea you FUCK I didn't know that until I almost hit your dumbass
