(Evo) Run stock ecu with no maf?!?!
Old Apr 12, 2008 | 06:56 AM
2ndGenDsm's Avatar
Default (Evo) Run stock ecu with no maf?!?!
I was reading somewhere I forgot where it was but apparently you can run your car with te stock ecu without the maf! Holy shit could you imagine that? Supposedly you can run a JDM evo 3-bar map sensor in place of the maf. Anyone know if this is true?
The reason I'm so interested in this is because I'm running a pt67 on my car and from a few people I talked to, I run the risk of my big ass turbo sucking in the honey combs from the maf straight into my turbo...not cool.
p.s. I DO NOT WANT TO RUN AEM EMS
and now introducing my newest toy...
-Silver Slow-poke-
Old Apr 12, 2008 | 07:57 AM
John's Avatar
lol @ tampa
so go with a GM maf conversion. I saw one working yesterday at CFT, a IX with 280 cams that idled smoother than a baby's butt. The test drive was pretty fun too, very smooth and drivable.
Now as far as I know, no Evo came with a MAP sensor, mitsu's in general have always been mass air flow
2008 AW 335xi coupe - Dinan stage 2 - DCI - Dinan axle back
|Full color business cards||flyers||postcards||more|
Old Apr 12, 2008 | 08:09 AM
2ndGenDsm's Avatar
I found this link on evom...
log boost with JDM MAP sensor (updated instructions) - evolutionm.net
apparently USDM Evos have a 1 bar MAP sensor that can only measure up to 2.2 psi of boost. However, the JDM Evo 9 uses a 3 bar MAP sensor that can measure up to 32 psi of boost.
So far they're using this jdm evo 9 map sensor as a boost controller.It's pretty acurate from the posts i read about it. But I guess it doesn't meet my needs when I go over 32 psi, will it?
my car idles like if i had an old big block chevy in my car...Totally does not sound like an evo, but it idles fine( just really f'ing loud ).
So John you're saying that this evo ran on stock ecu with no maf what so ever?
-Silver Slow-poke-
Old Apr 12, 2008 | 08:23 AM
ryu's Avatar
ryu
JUDGE RACING
It's still in development by the Ecu GURU pioneers on Evom but they are trying to get 100% reliability and accuracy from converting over to speed density on the stock Ecu which means no more stock air mas and no need for a GM MAF either. At that point the possibilities on tuning with the stock ECU are endless. Just look in the ECU flash forum in the tuning section on Evom.
Stock turbo/Stock Block- 10.80@125.97mph
FP Red/Stock Block- 10.301@132.93mph
http://www.youtube.com/watch?v=k2CqirgpFeM
Hta3582 w-.63Tial/Stock Block- 9.96@139.83mph
http://www.youtube.com/watch?v=rxjaKUnUZNk
Tampa's Quickest Mitsubishi
JUDGE RACING
Join us on Facebook
http://www.facebook.com/#!/pages/Judge-Racing/203463879689026
Sponsored by:
MAPerformance
Old Apr 12, 2008 | 09:23 AM
Jestr's Avatar
I've used the GM Maf with MAF-Translator to run 35+ psi. We even set a record of 597 hp at one point with the stock ecu. It drove around like a stock.
Ecu development will eventually reach the point to be able to use a map sensor. I think the main issues will be having a signal for IAT and Baro sensor.
Old Apr 12, 2008 | 09:38 AM
2ndGenDsm's Avatar
is the baro sensor for speed density? <---noob
-Silver Slow-poke-
Old Apr 12, 2008 | 04:04 PM
Jestr's Avatar
Barometric, IAT, and MAF signals all have to be compensated for since it's all present in the stock unit.
Old Apr 12, 2008 | 05:14 PM
F4A22's Avatar
Old School
Thats the pull you did at Buschur's right?Wasnt it like stock block or turbo?
Old Apr 12, 2008 | 05:38 PM
John's Avatar
lol @ tampa
no, its using a GM maf with a maf converter, tuned through the stock ecu, and set up as a blow through maf. I'm guessing the fact that its a flow through setup accounts for the improved idle.
Old Apr 14, 2008 | 03:49 PM
Jestr's Avatar
That was the Evo. It had a stock block and GT35R.
