new engine?
Hi guys.my engine is dead sow im looking for a new one.I'm going for a 4g63t since its a Mitsu. mirage sedan 95.i got the dohc head for cheap but im looking for a block 2.4.info I need is:
block 2.4 that mach the 4g63 1991 tsi head?
engine mounts?
transmission axles?
ecu and engine hardness?
turbo kit?
fuel system?
sow far I have shifter assembly
4g63tsi head
5 lug conversion kit brake kit
front mount intercooler 3"inlet out let
cf hood and trunk
strut bars
this is a thing that dsm tuners do a lot.sow if anyone has done this need help here
engine mounts?
transmission axles?
turbo kit?
fuel system?
4g63tsi head
cf hood and trunk
strut bars
well the ? marks I'm asking for info.the info for witch parts that i'll need to getthe others is the parts i already have bro
basic info on How to build a 4g63t 2.4 short block.the part I'll need and helpfll info
If you could form your post with complete sentences and questions it would help us understand and answer them with the best of our knowledge. Make each thing you are asking a separate complete question. That way they can can be answered separately and have full detail.
And so is not spelled sow.
sorry bro I'm like new.ok im looking to build a 2.4 4g63 on my mitsu mirage 1995 4 door sedan and I need all the info I cant get on this process
i know 2.4 came on expo models and on Galant.but what year?
I also know itll have to be early then 1996 since later models change the position of the engine.
The 2.4 is the 4g64 and from the sounds of your posts you want to build a 2.4 4g64 with a 4g63 head, correct?
What motor came stock in your car?
Also need to know if you want 6bolt or 7bolt setup.
And it's cool. It just helps make it easier to read and help with. Otherwise if it's too much trouble to figure out what someone is trying to say people will not bother replying with the info you just might be looking for. We try to separate ourselves from the honda forum on here.
Cause=Dsm, Effect=Mechanicalcoholic
