car reads half rpm
Old Mar 6, 2008 | 08:43 PM
bagabonesGSX's Avatar
Default car reads half rpm
my car is reading half the rpms it should be reading. it will tach out at 3700 rpm while I'm positive its more like 7800 rpm so its perfectly reading half the rpms it should. The cars setup is a common 6-bolt swap running a green top cam angle sensor and tuned off an SAFC. I guessing that the cam sensor is the culprit but wanted some opinions, so any help would be very much appreciated.
Old Mar 7, 2008 | 05:45 AM
Skip's Avatar
Throwback
Are you talking about the car's OEM tach? Or an aftermarket tach, or the afc?
Old Mar 7, 2008 | 02:56 PM
safc and factory tach.
Old Mar 7, 2008 | 02:59 PM
Ian MMF's Avatar
Omnipotence
Change the settings on the SAFC. Check the Vfaq!
Old Mar 7, 2008 | 04:24 PM
Skip's Avatar
Throwback
If the factory tach shows the same as the AFC - the afc is set correctly.
What did you do just before this occurred?
Old Mar 7, 2008 | 08:37 PM
going to the junk yard to geta new sensor tommarow I'll keep ya'll updated.
Old Mar 7, 2008 | 08:40 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
got 50 bucks?
-Dane
98 240 w/ bolt-ons
Srqspeed.com
