Umm... Help.
How do I know if I only need a new clutch disk or if I need a new pressure plate also? Since I wasted my clutch at the T&T My pedal has been much lighter. I noticed a difference starting a week or two before the T&T and when I slipped the clutch too much on a botched launch It wouldnt engage in second and would slip under aggressive throttle through 3rd and 4th. Its is semi grippy now but the pedal is weak. Do I need a PP too???
Joe
94TSiAWD
http://www.cr-racing.com/talonpage.htm
13.001 @ 106.55
Joe
94TSiAWD
13.001 @ 106.55
Thanx for your help Aaron... im that much closer to figuring this out now.
Joe
It might be wise to have on availible. You really cant tell until you open the tranny. I had mine at Jorges all week. I told him if I need on to order one. He told me that mine was fine but I would need a new on the next time. I had no problems with a soft clutch when Mine went out. Maybe the bearings in the PP are going bad to give you a soft clutch feel. Dont know.
James
Just another unreliable fast DSM
http://www27.brinkster.com/awd16g/
James
uhh it maybe still ok... im not really sure...try it out and see pulling out the trany agian really isnt that hard...if you need some help just ask...
ERIC
being a smartass
[This message has been edited by emodsm (edited 11-17-2000).]
ERIC
being a smartass
eric.
Build your car for YOU, not for the fame and glory. Fame and glory fade with time but YOU will be around as long as you live.
eric.
Dont worry guys... I will probably be looking for help.
p.s. the tranny is coming out once.
