egr ?
Old Sep 11, 2007 | 12:52 PM
smittyjr33's Avatar
Default egr ?
i dug deeper into my idle problem i did not bother to check the egr when i looked it has a 1g egr on a 2g manifold i bought it off ebay and just glanced before i put it on without checking it could this cause the rough idle?
Old Sep 11, 2007 | 01:39 PM
AnthrAxNSB's Avatar
first
...if there's a vacuum leak. You haven't thoroughly explained what your idle problem was/is.
Old Sep 11, 2007 | 03:09 PM
smittyjr33's Avatar
idles fine but when i put it in gears or revit up it dies immediatley. would the 1g egr on a 2g turbo cause me problems i guess what im wondering is can you use a 1g egr on a 2g?
Old Sep 11, 2007 | 06:22 PM
GsT Racer's Avatar
back in a 4g63
i dont think it matters, but you dont really need the egr anyways. try plugging off the vaccuum line that goes to the egr, and see what happens. your idle problem sounds serious though, I don't think an egr could cause that.
do you have a check engine light?
Old Sep 11, 2007 | 06:37 PM
AnthrAxNSB's Avatar
first
Originally Posted by smittyjr33
idles fine
Well, then why do you keep saying there's an idle problem/it idles rough?
Anyway, presently it sounds like you have a vacuum/boost leak. You can block off the EGR if you think/know that's where your leak is.
Old Sep 11, 2007 | 06:45 PM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
if the egr valve itself is leaking, it will not cause the engine to stall or run like that. the most you will have is an exhaust leak. just delete the vacuum lines and go from there.
SUCH IS THE RULE OF HONOUR.
Old Sep 12, 2007 | 07:37 AM
smittyjr33's Avatar
when i rev it the engine light comes on yes it idles rough
Old Sep 12, 2007 | 05:11 PM
AnthrAxNSB's Avatar
first
That is, unless the leak is at the gasket (where the EGR valve mounts to the intake manifold). That is what I was referring to, anyway. I assume by "EGR valve itself" you're not referring to the mounting service, though.
Old Sep 12, 2007 | 05:13 PM
AnthrAxNSB's Avatar
first
You should pull the code. If you don't have a scanner/logger, take it to Autozone. They'll pull it for free.
Old Sep 12, 2007 | 05:41 PM
I was referring to where the egr mounts to the intake. Unless the egr valve is still active, it will not cause any problems like that except for an exhaust leak.
If the egr isnt already deleted, get rid of it and cancel out one possibility. Like stated, pull the codes for the light.
