HELP 97 Rs stalls!!!
ok my girl has a 97 eclipse rs....the car usually stalls for no reason...when ur parked..or even when u are doin like 80 goin down the interstate...we had the car checked they said it was the egr valve...so we had it blocked off...it still did it...now someone is saying it could be the fuel pump relay.....so i put a new relay in an again still stalls....has anyone had this problem and if so....wat did u do to fix the problem....an does anyone have any ideas wat else it could be????
thanks
David
thanks
David
more than likely its' the cam angle sensor...especially if it's the 95 models...very prone to that...i know... i had a rs before. did that shit to me all the time. post up if it worked out.. and most importantly of all...rep me fool!!!
thanks
David
thanks
David
and now introducing my newest toy...
-Silver Slow-poke-
im gonna buy a new one tomorrow an see if that helps
Is your check engine light on? More then likely since you yanked out the egr but check for other codes as well. Go to 2GNT.com they should be able to help you out. Also there's a "key dance" trick to get the codes then right the number of flashes down to find out what the code(s) are. This all can be found on 2gnt, the link I posted within this post.
hey ur idea didnt work...we put a new on in an the car still did the same thing...any more ideas of wat it could be?
hey for some reason the car has not check engine light...it does not work...the car was bought used...an its never worked since day one.....so anyother ideas wat it could be?....
For one, you shouldn't really just replace parts left and right until you can be pretty sure you've narrowed it down as a culprit. If your cel doesn't work, then you should replace the lamp. You could even just swap it for something else in there cuz most of the bulbs are the same from what I remember. Once you're able to see the light illuminating, then you can do the suggested key dance and proceed from there.
-Xavier-
-Xavier-
Hook up an OBD II scanner and see what codes pop up. The check engine light not being on could be a (2) things... the light bulb went out or someone took it out.
Don't buy anymore new parts. You are simply wasting your money. First thing you want to do is see if the car is throwing any trouble codes.
