Need some help
Old May 22, 2007 | 12:02 PM
97 GST's Avatar
Default Need some help
Hey guys i have a 97 gst and i cant get the car to start because i have no spark at all on any cylinder. i know that the ECU is good and the transistor is good too i checked both of them. Any ideas what else i can check or what i can do to start the car?
Old May 22, 2007 | 02:17 PM
Figs's Avatar
NO START ISSUES
Check for fuel,spark,timing and compression.
Easy deductable method -
If you have compression - then you have a problem with the spark, fuel or timing
If you have spark and compression then check for fuel (do not just listen for pump) Pull return line and check for flow, if you have flow then spray some starting fluid or wd40 in the intake and see if it fires.
If you dont have fuel out the return line then check the filter, if still no go then pump.
If you have fuel check the injectors or ECU
IF you dont have spark check the fuses, check the power tr module, check the cas, and of course the ecu.
If you have fuel and spark - check firing order or timing.
Old May 23, 2007 | 07:28 AM
97 GST's Avatar
thanks man i will try that today and see if it starts.
Old May 23, 2007 | 03:57 PM
Figs's Avatar
No problem, let us know how it went.
