help with my door locks
Old May 11, 2007 | 01:16 PM
dsmdreamer's Avatar
Default help with my door locks
ok well when i got my 2g my power locks didnt work, i have replace everything i can think about replaceing on the system and still cant get them to work. replaced the relays under the radio, replaced the motors for the locks, replaced the hole assembly with motors again, repaced switches. still no power lock.
the problem im haveing is i got part of the system to work, orignaly the motors were all burned out. i found out that the power lock was stuck on lock and the motor would keep trying to spin, (hence killing my battary) and messing up the motor, so i got all new assembly and now the motor keeps going to the lock and its supposed to revurse when you hit unlock, all it dose is stop...then when you let go of the unlock it goes right back to trying to lock.
so long story short, something is keeping my locks in the lock possition and i have replaced everything i can think of, is there anything else someone can think of? i got door switches, motors and assemblies, and relays under the radio, is there anything else i should look at?
Old May 11, 2007 | 02:17 PM
dsmdreamer's Avatar
can a mod. please move this to the correct area, sry, my bad.
Old May 11, 2007 | 04:12 PM
Figs's Avatar
You have the door lock curse. I had it in my 1997 and its not ideal to try to fix it. Instead of going through the hassle, I pulled the fuse and just used them as manual locks. Mine would get stuck, lock me inside the car and wouldn't unlock, would unlock then lock by itself a second later, unlock one door and lock the other. They were acting wacky, I posted a thread about it and I was told I got the door lock curse that some 2g's end up getting. That's all I can share with you, I've been in your shoes.
Old May 12, 2007 | 04:33 PM
Dario99gst's Avatar
Tu Papi Chulo
If I were you instead of trying to fix the problem just bypass it all together.
In my 95 gst the locks stopped working alltogether. All I did was install an aftermarket lock kit on both doors and never had the problem again. Just make sure who ever does it for you knows what the hell they are doing. PM me if you need help finding someone.
-Dario
DiSplaceMent Replacement
IF YOU NEED ANYTHING FROM CHASE PM ME!!
