Help
Old Mar 29, 2007 | 03:38 PM
NightRdnEclipse's Avatar
Ralfy
Default Help
92 GSX gauge cluster problem.
When I bought the vehicle, only the RPM's where working, so I took the cluster apart, put it back together, and now nothing is working. Im not to sure that it would matter but the car has a gvr4 tranny. I couldnt find much on a search. Any help appreciated. Thanks
-Ralfy
-Ralfy
http://www.myspace.com/ralfy4
Old Mar 30, 2007 | 01:13 PM
Figs's Avatar
Being that you took it apart and I don't know the extent of you taking it apart. I would try to get a hold of a 91-94 turbo Gauge Cluster that is working and see if it works. It's a process of elimination. But I find it wierd for the tach just to work and the water temp, oil press., speedometer not to work. So I would start by finding someone with a spare 91-94 turbo gauge cluster that will let you test it in your car (before buying it) and see if it works. If it does then your old gauge cluster was faulty. I would start there though in my opinion.
Old Mar 30, 2007 | 06:27 PM
Ralfy
An extra cluster came with the car, and I tried that one also but chances are that one is bad also. Thanks ill see if I can find an extra cluster somewhere.
-Ralfy
