Need some help!
Old Jan 29, 2007 | 04:21 PM
98_GstEclipse's Avatar
Default Need some help!
Where is the fill plug on the tranny and where is the drain plug? I tried for over an hour tryin to figure out which bolt is which and I couldnt figure it out. The 1 bolt I thought was the fill plug wouldnt come off so Im gonna go to my friends house 2morrow and use his compact gun. I know I sound stupid asking a dumb question like this but its my 1st time so I thought I would go to the professionals. Plus I drove half way around the world just to get Royal Purple 75w 90 gear oil and I wanna try this shit out. Can some help me out here!
Old Jan 29, 2007 | 05:20 PM
TrboANTsi's Avatar
FL,..gods waiting room!!
VFAQ Site - Visual Frequently Answered Questions has good pics there for you hope it helps!
Old Jan 29, 2007 | 05:32 PM
Thanx!!
Old Jan 29, 2007 | 08:08 PM
Radek's Avatar
Transaxle Fluid Change
Old Jan 29, 2007 | 08:09 PM
Radek's Avatar
BTW what the hell is a compact gun
Old Jan 30, 2007 | 01:47 PM
lol. its like an air compressed power drill i guess. it helps out alot of bolts that are stuck or tight as hell
Old Jan 30, 2007 | 04:57 PM
BoostLogik's Avatar
BoostAddict
Exactly. Those bolts can be a bitch to break loose some times.
"Even through the darkest days, this fire burns, always"
Old Jan 30, 2007 | 05:05 PM
THE_ONE's Avatar
*Turbo Interceptor*
STOPPPPP!!!!!!!!!!!!!! Do not use a "COMPACT = IMPACT--GUN you mean on the bottom tranny drain plug. Not enough surface to grab onto and you can strip it. Only use it on the fill plug at the top of the tranny under the shift cables!!!!!!!!!
Old Jan 30, 2007 | 05:45 PM
BoostLogik's Avatar
BoostAddict
Shit, I didn't even read into the lines that well.
Yeah, I wouldn't use an impact wrench on those things. If the bottom is stuck on severly, try using some lubricant (PB Blaster). Those that tend to have trouble, usually take a breaker bar to it, but using it in a "cautious/careful" method.
Old Jan 30, 2007 | 06:45 PM
Yea I just finished like 2 hours ago. I only had to use the impact gun on the fill plug. That 1 was a bitch and the drain plug came off with no problem and Royal Purple Gear Oil is badass! I recommend it to every1! My opinion tho
