Profec help
Old Sep 19, 2006 | 01:58 PM
TSiRacer's Avatar
Killing Clutches Since 04
Default Profec help
OK I have aGReddy Profec A. I know ...a Profec A!!! Anyways, I need to get my hands on this diagram I used to have explaining how to hook up all of the vacuum lines. it used to be online and I had even printed it, but cant find it now. the only reason i need it again is becaus I moved the dip switches on the back of it, and cant remember how to set the number 4 switch. Wastegate,actuator. Thats it. Thanks all
......keep it boosted....
Old Sep 19, 2006 | 02:18 PM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
its under tech support.
SUCH IS THE RULE OF HONOUR.
Old Sep 20, 2006 | 03:55 AM
TSiRacer's Avatar
Default Profec help
You said it was in the tech support/ Im not following you on that. Where is that at? All I need to kbnow is whick way to set my dip switch , for either actuator, or wastegate. Im thinking actuator since I have a internal wastegate. Thanks again.
Old Sep 20, 2006 | 11:30 AM
tech support, on the top right page of greddy.com its one of the links you can open up.
Old Sep 20, 2006 | 11:34 AM
YARO's Avatar
Smith & Wesson Protected.
http://greddy.com/img/PHP/products/pdf/688.pdf check if that works!
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Sep 20, 2006 | 12:06 PM
thanks, im at work right now and cant pull up the link.
