Stuck nut, of course!
Old Sep 14, 2006 | 10:12 AM
eclipsegst303's Avatar
.:DSM:.
Default Stuck nut, of course!
Well, installing my turbo is not going smoothly at all....Everything came off pretty well yesterday, but now I was about to put on my oil lines, and the nut on the oil filter housing wont come off at all....
Apparently my camera doesn't like taking close ups of anything, but you can still tell what I'm talking about. The nut is 2 pieces, I got the middle one out, but the oil line threading doesn't fit into it, so I think I need to get the whole thing off. As you can see, the big part doesn't go straight in, it goes in at an angle. Is that normal? How the hell am I going to get this thing off? I have been hitting it with a hammer, pb blasting it, prying the hell out of it, and nothing.
Old Sep 14, 2006 | 12:35 PM
byondevl's Avatar
Made Of Scars
Soak the fuk out of it wiht pbblast, a few times a day...let it sit for a day or so while periodically spraying it with pbblast.
Old Sep 14, 2006 | 12:57 PM
quadzilla's Avatar
I would do the double nut trick and just take the entire fitting nut off then go from there.
"Sit right here pimpin,let daddy holla at ya,Now daddy can do this ALL DAY, EVERYDAY,NO PROBLEM". MAKE A PIMP DECISION
Old Sep 14, 2006 | 01:08 PM
.:DSM:.
I have to take the entire fitting nut off....Thats whats stuck. I tried looking for an adapter at home depot that would go into the stuck nut, and then also fit the oil line, but the one that looked like it might work, they were out of, so I need to go to another one and see if they have it.
All im not sure about is if the stuck nut is supposed to be at an angle like that. If it isnt, that means its cross threaded, and I dont want to take it off, because then I wont be able to put the new one in anyways.
Old Sep 14, 2006 | 01:11 PM
mitsu420aT's Avatar
i just went and looked , yes mine is in an angel as well. good luck.
( mine was replaced by the dealer last month)
Old Sep 14, 2006 | 01:29 PM
boosteddsm's Avatar
Awd the enemy of fwd
Leave it alone. And run your feed from your head to the turbo.
2 Step @ 1.5 bars..... Who wants some
And I thought that AWD is to have traction.
Old Sep 14, 2006 | 01:46 PM
.:DSM:.
Don't have a fitting that will fit into the head. And the stock oil line is fucked anyways.
Old Sep 14, 2006 | 01:55 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
mine goes into the head, but i had the same thing happen to me, i would either leave it alone and go to the head or get a tap and die set
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Sep 14, 2006 | 02:22 PM
.:DSM:.
I got the stuck one off, but of course the new one I bought doesnt fit. Why would it, right?
Old Sep 14, 2006 | 02:38 PM
Chris LS's Avatar
just blaze...
That sucks when that happens, good luck to ya.
Quote : I'm Slow:
Less hours = less $$. Less repetitive 'ish every day = PRICELESS!
