how to check for boost leaks
Old Sep 3, 2006 | 12:18 PM
BDIX's Avatar
Dick is Huge!
Default how to check for boost leaks
like the title says..
tomorow I'm performing a full tune up on the car.. new plugs and wires and oil change blah blah and a basic cleanning because I've pretty much forgot about the car lately
how do you guys do it?
how much would i have to pay for you guys to do it?
or is this a site or a webpage that shows you how to do this that you could direct me towards?
Totalled his shit!@
Old Sep 3, 2006 | 12:33 PM
2g's Avatar
2g
IC Pipe Tester
Old Sep 3, 2006 | 12:40 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
go to home depot, figure out how big the outer diameter of your turbo inlet is, get a pvc cap (somehing like this and drill a hole http://www.optics.arizona.edu/Academ...pes/EndCap.jpg) and coupler that fits on each. get a valve stem, drill a hole in the pvc cap and pull the valve stem through, put some epoxy or something around the valve stem and hook it to your turbo, listen for leaks.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Sep 4, 2006 | 07:41 AM
S281_158's Avatar
way over the limit
thats what o did for the srt4 and it worked great you can use the pressure regulator on the compressor to set how much boost you car is actually running...that way you know exactly what your car is doing under boost
NOS is like a hott woman with std's u know u want to hit it but afraid of the consequences
01 Phantom Nemisis Unlimited Allstar
-100cc Parilla TT75/85 Hybrid (Ported)
-Dual Big Bore Carbs
-TSOW Pipe
-Horstman Axle Clutch (Blueprinted)
42hp on DynaJet Dyno
96 Saleen S281 #158 Black
06 Acura TSX Royal Blue Pearl
01 Acura MDX Touring
01 Dodge Dakota
