Problem shifting...
Old Aug 3, 2006 | 06:47 PM
ThE iNfAmOuS p MoNeY's Avatar
Tampa Bay Tuned Inc.
Default Problem shifting...
ok folks...so i have this extremely annoying problem with my GSX...when i first start it up and drive it, it shifts perfectly...but about 10 minutes into driving it, it gets really hard to change gears...the problem is mostly from a stop....i clutch in to put it into first gear but it doesn't shift...i hafta pump the clutch and force it in really hard into first...and the shift into second is a little rough too...and third...and reverse...so yeah...not cool...i just put a new clutch in it today and bled the hell out of it...i knew that wasn't the problem but i def. needed a new one...so yeah..and because i hafta almost force the car into gear, the shifter broke off the shift plate...i bolted it back on but it keeps on loosening up when i shift...i kno i def. need new bushings....but yeah...what do u guys think the problem is?... def. appreciate....thanks...*
Old Aug 3, 2006 | 06:50 PM
Spydergirl's Avatar
you think I care....why?
Did you check the Master and the slave? Mine were leaking, and I had to have EVERYTHING replaced. *my car was doing the same as yours*
There are two kinds of riders...the ones that have been down and the ones that are going down.
Originally Posted by DaniellaRella
Why dont you try to argue with someone who gives a shit what you say.
Old Aug 3, 2006 | 06:53 PM
oooooo....thanks....i'll def. check that out...
