4G63 MBC Install
Old Jul 29, 2006 | 01:24 PM
So_Sli's Avatar
Default 4G63 MBC Install
I bought a Turbonetics manual boost controller, and the directions say I have to hook one side of the MBC to the wastegate's "vacuum port." Exactly where is this? I have a JDM 6-bolt engine, and I see the wastegate just under the intake pipe. There's a hose tapped into the side of the wastegate, which runs to a "T". The two other hoses connected to the "T" are as follows: One runs to the J pipe (the one that hooks up to the turbo and heads to the intercooler), while the other runs to a cap (I plugged off this line when I took out the faulty MBC the guy before me had in the car). Long story short...I'm not seeing a "vacuum port," and the instructions that came with the show that I have to hook the other side of the MBC to this so-called vac port. Here are the instructions:
I'm not seeing a vacuum port or a flange...HELP?!
Old Jul 29, 2006 | 02:09 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
those instructions are for an external gate, and it sounds like you have an internal. hook 2 vacuum sources to the T (one from the BOV, and another from your intake manifold) and then the other hole on the T should be connected to the "boost source" side of the MBC(i believe), and then connect another vacuum line from the other side of the mbc to the wastegate actuator.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Jul 29, 2006 | 02:33 PM
So_Sli's Avatar
Wha?
Old Jul 29, 2006 | 03:05 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
ok you have a brass colored wastegate actuator.....hook a line from your intake manifold and bov to a T line. from there hook that to the in part of the mbc, on the other side of the mbc hook a line from there to the wastegate actuator.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Jul 29, 2006 | 03:15 PM
So_Sli's Avatar
LoL I don't think you understand how ni--I mean...AFRO ENGINEERED...my car is. It's a 6-bolt VR4 swap, and I just found out that the 2 hoses that came from the wastegate actuator are cut. My wastegate actuator does nothing...it's connected to nothing. Fuck.
Old Jul 29, 2006 | 04:05 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
so connect it! its not hard to hook up a mbc, you just gotta have vacuum lines.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Jul 29, 2006 | 08:15 PM
AnthrAxNSB's Avatar
first
Your an ass and I hope you sell your car.
Old Jul 29, 2006 | 10:20 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
just redo the vacuum lines, take out the cut ones and redo them like i said
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Jul 29, 2006 | 10:49 PM
So_Sli's Avatar
I hope you're joking. If not, where's the beef?
Old Jul 30, 2006 | 07:12 AM
BDIX's Avatar
Dick is Huge!
Whatd he do?
BTW welcome to mitsu tech!
Totalled his shit!@
