car is boosting 15lbs w/o mbc
Old May 30, 2006 | 04:08 AM
BDIX's Avatar
Dick is Huge!
Default car is boosting 15lbs w/o mbc
okay so whats the problem..
Ive heard 2g's boost like 12 stock and jump up a littile bit with a aftermarket BOV because the stock one leaks. The BCS is removed as well.. would this justify 15lbs with 17 spiking.
Totalled his shit!@
Old May 30, 2006 | 08:11 AM
mitsu420aT's Avatar
i would say it has to do with your wast gate maybe going bad
or a whole or crack in the line
Old May 30, 2006 | 08:16 AM
Dario99gst's Avatar
Tu Papi Chulo
No that's normal did you take the BCS out completely or did you just take the restrictor out? I told you in another post that that was what I was running and I didn't have a boost controller.
-Dario
DiSplaceMent Replacement
IF YOU NEED ANYTHING FROM CHASE PM ME!!
Old May 30, 2006 | 08:22 AM
BDIX's Avatar
Dick is Huge!
alright just checkin..
just to make me feel better I can turn it down with a MBC right?
Totalled his shit!@
Old May 30, 2006 | 08:34 AM
GsEclipse02's Avatar
a down pipe might do this as well for you
Old May 30, 2006 | 08:58 AM
Dario99gst's Avatar
Tu Papi Chulo
i dont see why not... you could also just put a vaccum line from the source directly to the wastegate. I think thats only 8psi
-Dario
Old May 30, 2006 | 09:07 AM
Ender.'s Avatar
Eis Aner Oudeis Aner
If it is on the T-25 I really wouldnt worry about it...
Or do what Dario said and just run a vac line from the wastegate to the source and run 8-10 psi. Its how mine is set up and it hold 10 psi then creeps up to about 12.
Old May 30, 2006 | 10:27 AM
25psi's Avatar
Treated and Released
Sounds about right for a 2G with an upgraded BOV and BCS mod.
-Jim
“Equality, rightly understood as our founding fathers understood it, leads to liberty and to the emancipation of creative differences; wrongly understood, as it has been so tragically in our time, it leads first to conformity and then to despotism”-Barry Goldwater
Old May 30, 2006 | 02:16 PM
BoosTb4BroaDs's Avatar
Only problem i see is why aren't you running more
Old May 30, 2006 | 02:29 PM
Figs's Avatar
T-25 hates more boost
