bov question
Old May 29, 2006 | 11:54 AM
TurboBob's Avatar
Default bov question
why cant i pull off the tube from my stock bov to the intake ,every time i atemp this the car idles funny, ive also blocked off the same tube so that it doesnt loose vacume ,so when i rev it up high when the revs come down it stalls im guesing that it has somthing to do with the mas air ,but what ? and how do i get the bov noise ,and the car to still run good and no rough idle?????
98 LS INTEGRA
91 talon tsi
Old May 29, 2006 | 01:02 PM
Dario99gst's Avatar
Tu Papi Chulo
the mass has already added fuel for the air that you are dumping out. so it runs richer while you are coming down and then it dies. the best way to overcome that issue is speed density. (maybe gm maf I've never used it so i don't know) I would route it back in if i were you the car runs and shifts so much better when you do. If it weren't because I know I'm going to go AEM then I would stick with a type R and route it back in.
What bov are you using anyway? FYI the stock plastic one is pointless if you don't route it back in.
-Dario
DiSplaceMent Replacement
IF YOU NEED ANYTHING FROM CHASE PM ME!!
Old May 29, 2006 | 01:07 PM
DSMboost97's Avatar
How long will it last?
Do a search, you find everything you need to know about it. Bascially the car meters how much air it senses is going to the engine and when you take the tube off, some of that air doesnt make it into the engine like it does with the tube connected. But the ECU doesnt know that there is any less air so it still adds the same amount of fuel causing it the run very rich.
Old May 29, 2006 | 02:17 PM
TurboBob's Avatar
i dont have it disconected it was only the few times iv'e tried it that it did that and the bov is stock metal bov its not plastic do any of you know where i can research on getting a gm mass hooked up and what i am going to need thanks apritiate it !!!!!
98 LS INTEGRA
91 talon tsi
Old May 29, 2006 | 03:46 PM
Dario99gst's Avatar
Tu Papi Chulo
Do searches bro all this info is posted on line...
so if you have a metal one that means you have a 1g. And I never said that the gm maf would fix that problem.
-Dario
Old May 29, 2006 | 04:36 PM
Figs's Avatar
I wouldn't hurt the cars peformance just for a sound. Get a crushed 1g bov and you would hear a nice sound with the recirculation tube. I tried what you did when I had my TSI and it did the samething. The recirculation tube is there for a reason.
Doing a GM MAF setup may solve the problem. Finding a used VPC setup would be best. HKS doesn't make them anymore last I heard.
Old May 29, 2006 | 05:07 PM
Dario99gst's Avatar
Tu Papi Chulo
they are expensive as hell now. like 450-500
-Dario
Old May 29, 2006 | 05:19 PM
Ender.'s Avatar
Eis Aner Oudeis Aner
Just recirculate it. If you want a sound, get an aftermarket BOV.
Old May 29, 2006 | 08:03 PM
jtr's Avatar
jtr
the r1pper
get a 1g crushed bov, put that on, recirulate it back to the intake, shoulda make a nice sound, and wont die, then once uhave enough for gm maf, just upgrade and remove it, but right now im not recirculating mine, i just slow it down with grears and is fine, just my 2 cents
