oil cooler questions???
Old May 28, 2006 | 07:24 PM
JR.'s Avatar
JR.
Arrow oil cooler questions???
ok from what i have reed all the 90 dsms have an externall oil cooler witch is a air to oil cooler....if u have one of this air to oil coolers can ur oils still mix with the coolant and have oil in ur radiator??????
98 talon awd automagic
Old May 28, 2006 | 09:13 PM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
your car doesnt have a 90 oil cooler unless you put one back on. with the oil cooler you have on your car, its possible for it to do that, or blown head gasket again.
SUCH IS THE RULE OF HONOUR.
Old May 28, 2006 | 09:29 PM
JR.'s Avatar
JR.
i put a new head gasket about 1 month algo..... so what also can it be if is not the damn oil cooler????
Old May 28, 2006 | 09:36 PM
try changing out the cooler that you have. those are easy to fuck up and damage.
Old May 28, 2006 | 09:40 PM
JR.'s Avatar
JR.
so witch one do i have the oils to coolant or the air to oil????
Old May 28, 2006 | 09:47 PM
the 90 oil coolers are in front of the ac condensor on the driver side. there would be a bracket with 2 studs if its not there. from what i saw when i looked at your car, it looked like you had a 91 oil cooler.
