Wtf?
Old Apr 16, 2006 | 10:14 AM
naciamaj's Avatar
MY LIFE, YOUR VACATION
Default Wtf?
Alright so I adjusted my clutch so that it didn't grab on the floor, but when I would have to start my car I would have to push the clutch to the floor (since I didn't disconnect the starter clutch switch) and it would be very hard because the pedal wouldn't want to go to the floor. Long story short all of a sudden while I am driving my clutch or flywheel started making a scraping noise and it wouldn't engage correctly. Today when I tried working on it I jaked it up and put it in gear and I noticed that the left wheel wasn't moving, just the right. I am wondering how this could have happened and how I might be able to fix it. Thanx for your help.
"She told me it's just a car, I told her shes just a girl."
AIM : SurferDudeCLW
[url]http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=491 27763
Old Apr 16, 2006 | 01:08 PM
Figs's Avatar
I don't get what you said but if its fwd and you start it and someone puts into 1st gear and gives it gas only 1 wheel will spin. If they throw it in reverse the opposite wheel will spin.
A scraping noise might be your throw out bearing. Tend to do that when their not installed correctly or weren't properly greased.
Old Apr 17, 2006 | 03:18 PM
naciamaj's Avatar
I think I might have blown out my master slave cylinder, because the clutch doesn't engage right and a makes a scraping noise as two metals were scraping.
AIM : SurferDudeCLW
Old Apr 17, 2006 | 03:22 PM
Figs's Avatar
Check for leaks. Usually if the seal goes bad in the master cylinder it will tend to leak inside the car. Just look inside the car and look up against the firewall to see if there's a trail of fluid going down. Slave cylinder leaks as well at the rubber boot. If you pull the boot and fluid comes out then I would assume its no good because thats what happened to the slave cylinder on my old 1g.
Old Apr 19, 2006 | 05:16 PM
naciamaj's Avatar
True I will check, it sucks though because I just got a whole new tranny,clutch,master,and slave cylinder. I just want to make sure that is it, but I will check for the leaking. thanx
AIM : SurferDudeCLW
Old Apr 19, 2006 | 07:16 PM
Dario99gst's Avatar
Tu Papi Chulo
Who did the tranny? are you sure that it was installed correctly? The TOB would make that kind of noise.
-Dario
DiSplaceMent Replacement
IF YOU NEED ANYTHING FROM CHASE PM ME!!
Old Apr 21, 2006 | 07:05 PM
Figs's Avatar
Yep especially if it wasn't greased. Its a nasty sound, heard it before.
Old Apr 21, 2006 | 07:22 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
maybe someone needs to follow instructions, right in the damn book it says GREASE SPLINE~!!!!!!!!! theres a reason, they arent just takin up space with those instructions
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Apr 26, 2006 | 07:19 AM
naciamaj's Avatar
I got my tranny, clutch, flywheel, master, and slave cylinder done at sidewinder while I worked there. Art and I both did it. Everything is done correctly I greased the splines thankyou. It's becuase the slave cylinder isn't engaging all the way. I am in the prossess of fixing it now.
AIM : SurferDudeCLW
Old Apr 26, 2006 | 07:34 AM
Chris LS's Avatar
just blaze...
What are you doing to make it engage correctly?
Quote : I'm Slow:
Less hours = less $$. Less repetitive 'ish every day = PRICELESS!
