Overheating and Don't know Why?
Old Mar 24, 2006 | 04:43 PM
naciamaj's Avatar
MY LIFE, YOUR VACATION
Default Overheating and Don't know Why?
Well long story short. I had my car sitting for like a month or so and the first time that I went to drive it was overheating very badly, so I figured that it was the antifreeze mixture. So I put some 50/50 in with some water wetter and it would still overheat, but not as bad. So then I changed the radiator cap thinking it was releasing some steam. Now for some reason it will only overheat when I drive it for a long time at around 3500 rpms and if I put my heat on it's straight it won't overheat. The only other thing that I could think that it could be is my radiator hose is bad, but it looks straight and doesn't seem to be showing signs of old age. Anyone got any ideas???
"She told me it's just a car, I told her shes just a girl."
AIM : SurferDudeCLW
[url]http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=491 27763
Old Mar 24, 2006 | 06:15 PM
bagabonesGSX's Avatar
dude this is so simple, its most likely the thermostat since it has been sitting it got dry and deceided to seize since antifreeze is also made to lube the small amount of parts it has to lube....
Old Mar 24, 2006 | 06:16 PM
AnthrAxNSB's Avatar
first
As long as you're not pushing any coolant, bagabonesGSX is probably correct.
Old Mar 24, 2006 | 07:04 PM
mitsu420aT's Avatar
Old Mar 25, 2006 | 04:13 AM
Figs's Avatar
Sounds like the thermostat... you be amazed on a part that only cost $3-10 how much damage it could cause.
Old Mar 25, 2006 | 07:46 AM
BOX SENTRA's Avatar
OG MUDBONE 240sx
thermostattttt its the only thing it can be
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Mar 25, 2006 | 08:47 AM
DeadSexY's Avatar
diballacully slow
crankwalk
j/p
http://www.machv.com/mitoemther.html
Old Mar 25, 2006 | 07:15 PM
Autobot's Avatar
4G63er
replace with OEM thermostat.
