Stud broken
Old Oct 30, 2005 | 12:46 PM
FiLjAr4LiFe's Avatar
www.myspace.com/filjar
Default Stud broken
Broke a stud connecting exhaust manifold to head.
1) How do you suggest i get it out?
2) WHere do i get a new one?
THanks,
Aaron
Old Oct 30, 2005 | 12:55 PM
Ian MMF's Avatar
Omnipotence
Easy out
mitsu oem
Old Oct 30, 2005 | 03:34 PM
Ender.'s Avatar
Eis Aner Oudeis Aner
Yeah, its not the end of the world... I had like 3 broken on my old car. But ez out and replace with SS Studs you can find them from any DSM vendor.
Old Oct 30, 2005 | 04:03 PM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
you can do it eeebbbayy. stainless too.
SUCH IS THE RULE OF HONOUR.
Old Oct 30, 2005 | 06:31 PM
What is easy out?
Old Oct 30, 2005 | 07:36 PM
TheRedDragon's Avatar
there like a tap type dea
Gseclipse02l
Old Oct 30, 2005 | 07:52 PM
AnthrAxNSB's Avatar
first
If a "grippable" amount of the stud is out of the head, use a vice grip. If not, you drill a hole and use an "easy out". An easy out reverse threaded so that as you're turning it in a direction that would remove a bolt or screw, it's turning into the hole that you've drilled (grabbing the piece (stud) tighter the more you loosen it). You can purchase them at Autozone. Just make sure you get one small enough to fit into the hole you've drilled.
Old Oct 31, 2005 | 08:11 AM
Jordan Y.'s Avatar
15 seconds EXHILARATION
Don't use a screw type easy out, it will crack aluminum.
Procedure:
If it's sticking out, vice grips.
If it's inside, harder procedure-
1. center punch a dent in the middle of the stud
2. take a small drill bit, drill a pilot hole into dent
3. take the proper size drill bit, drill the ez out hole into stud, don't go too deep- take out another stud and mark the bit with the proper depth if you have to
4. make sure you don't measure on one of the holes that goes to an oil passage
5. use a hammer-in extractor only, screw type will crack the head
6. getting a proper tap T handle really helps if you can't get much depth on the drill hole
Old Oct 31, 2005 | 08:36 AM
Thanks a lot guys, I'll try this out today.
