installing
Old Sep 9, 2005 | 01:43 PM
dsmtuner's Avatar
gotta love the boost
Default installing
which wire on the air fuel gauge do i tap into. 90 talon n/a 4g63
SVT F150
Old Sep 9, 2005 | 03:07 PM
91TSI_AWD's Avatar
Resident Galant Guy
There is a single pin connector that goes to the passenger kick panel, its a little bit up from the floor, but can be seen when you get down there. Its a black connector, and that is the O2 sensor check point, you can just use that lead there for your gauge.
Mike
95 Lancer GSR
93 300ZX 2+2
Old Sep 10, 2005 | 12:09 AM
Frankie Figs's Avatar
Too Much is ALMOST Enough
Those gauges are worthless cuz 99% of the factory O2 sensors are narrowband (0-1 volt) You need a wideband (0-5 volts) signal to be able to actually monitor whats going on. A narrowband signal will only tell you if the air fuel ratio is lean, correct or rich. By lean or rich I mean leaner or richer than it should be, even if its only .1 more than it should be. Just stop being cheap and buy a wideband O2 sensor if you really care. I got my PLX-M300 for $313 shipped from www.streetrays.com
Old Sep 10, 2005 | 12:12 AM
Brandon's Avatar
Resident Dingo
PLX R-500 owns you... best evAr
Old Sep 10, 2005 | 01:30 PM
dsmtuner's Avatar
the only connector was one that was closed up and it had three wires coming out of it.if this is the connector which wire gets hooked up,to the gauge.
SVT F150
Old Sep 11, 2005 | 10:55 AM
91TSI_AWD's Avatar
Resident Galant Guy
its a single connector its, taped up on the harness. remove some of the electrical tape thats consealing everything.
Mike
95 Lancer GSR
93 300ZX 2+2
Old Sep 11, 2005 | 11:31 AM
dsmtuner's Avatar
and this wire is also on the n/a harness.
SVT F150
Old Sep 11, 2005 | 04:26 PM
91TSI_AWD's Avatar
Resident Galant Guy
dosent matter. Its still an eclipse. they all had these test connectors.
Mike
95 Lancer GSR
93 300ZX 2+2
Old Sep 12, 2005 | 02:10 PM
dsmtuner's Avatar
yeah i found the wire all the way up there.gauge works good. thanks for everyones help.
SVT F150
Old Sep 12, 2005 | 02:56 PM
91TSI_AWD's Avatar
Resident Galant Guy
Welcome.
Mike
95 Lancer GSR
93 300ZX 2+2
