help
Old Apr 15, 2005 | 05:19 PM
tampatsi21's Avatar
Ian
Default help
has anyone had trouble with having low or no compression after doing a timing belt??? let me know please
Old Apr 15, 2005 | 05:53 PM
LS1Fever's Avatar
yes, its expected when you break a timing belt. all the intake valves and sometimes most/all the exhaust valves are bent, causing little to no compression.
Old Apr 15, 2005 | 05:56 PM
tampatsi21's Avatar
Ian
i didn't break the timing belt though
Old Apr 15, 2005 | 05:58 PM
LS1Fever's Avatar
then something else is wrong. did it slip any teeth?
Old Apr 15, 2005 | 06:03 PM
tampatsi21's Avatar
Ian
i dont know, thats what im thinking is wrong though, im gonna take it all apart again tomarrow at work and find out
Old Apr 15, 2005 | 06:04 PM
LS1Fever's Avatar
well, what all is the car doing? how is it idling? is it smoking bad? smoking at all? just explain what the car is doing.
Old Apr 15, 2005 | 06:09 PM
tampatsi21's Avatar
Ian
right now it dosent run at all, it wont even start, the motor just turns,it's getting fuel, it's getting spark, but no compression.i pulled the valve cover and all the valves were working and opening and closing like they should
Old Apr 15, 2005 | 06:51 PM
Skillionaire's Avatar
Nobody
Timing is off, try setting it again
"So...is there any tread left on the tire..or at this point would it be like throwing a hotdog down a hallway"
-Stewie (Family Guy)
Old Apr 15, 2005 | 07:06 PM
tampatsi21's Avatar
Ian
thanks i'll try that
Old Apr 18, 2005 | 06:15 PM
tampatsi21's Avatar
Ian
thanks for the advice guys, timing was off runs great now
