vpc chip reprogramming
Old Dec 13, 2004 | 09:29 AM
russellbeermann's Avatar
F*ck da rent, get the Lex
Default vpc chip reprogramming
i'm using a hks vpc and gcc in my gst and i'm moving from 550cc to 740cc injectors. i was wondering if anyone knew where i could get my chip reprogrammed for this. thanks
Russ
03 Infiniti G35
01 Lexus IS 300
99 Acura TL - for sale
96 Honda Civic DX - for sale
Old Dec 13, 2004 | 09:33 AM
maybe i should put this on a toyota forum...
Russ
03 Infiniti G35
01 Lexus IS 300
Old Dec 13, 2004 | 09:47 AM
Jordan Y.'s Avatar
15 seconds EXHILARATION
There are only three chips, the 450 chip, the 550 chip, and a chip that afaik was made by Buschur (can somebody confirm this?) the 660 chip. The best you could do would be to use that, then make final adjustments using whatever adjustment capability you have with the gcc. I don't know if it's enough, I've never even seen one in person. Another option would be getting a chip burned to take up some of the injector compensation slack, enough to make up for the difference between 740's and a 550/660 chip. You could talk to Jeff O. at dsmchips.com and see what he thinks.
Old Dec 13, 2004 | 01:56 PM
nouseforaname's Avatar
16.4@84mph
I have both a GCC and 660cc chip for sale.
813-610-2563
89 Mirage-Intake/Header/Exhaust
AIM-queerpuncher
Old Dec 13, 2004 | 02:01 PM
LS1Fever's Avatar
the biggest chip they make for vpc is a 720.
Old Dec 13, 2004 | 05:57 PM
720?? i only knew of 660 also, but i heard that some supra shops will "reprogram" a chip to match your injectors.
Russ
03 Infiniti G35
01 Lexus IS 300
