Brakes Vibrating
Old Oct 15, 2004 | 03:19 PM
JDMBlackGSR's Avatar
Gators Bitches!
Default Brakes Vibrating
Ok, I posted this a few weeks ago saying that my friends car is shaking when stopping. Well she left for the weekend and I took the car, and got new rotors and put them on. It is still doing it now after they have both been replaced. So what else should I look at here, if it is not the rotors? Thanx
Old Oct 15, 2004 | 07:53 PM
TBSpyder's Avatar
When all else fails, take it to Just Brakes and don't forget the lube.
Old Oct 15, 2004 | 09:07 PM
BoostLogik's Avatar
BoostAddict
It's probably the wheel bearings, as I mentioned in the other thread. If the rotors don't fix the "warped rotor" shake, it's most likely the bearings.
"Even through the darkest days, this fire burns, always"
Old Oct 16, 2004 | 06:04 AM
Gators Bitches!
how can i tell.....can you see it or is it something that i have to take off?
2003 Accord EX-L V6
Interior
'07 Shift Lever♦Diode Dynamics Stage 1 LED's
Exterior
HFP Front & Rear Lip♦Limo Tint♦LED Smoke Tails♦Yellow Fogs♦8000k Low Beam HIDs♦LED Reverse Bulbs♦Gunmetal Stock 7 Spokes
Suspension
Rear Lower Tie-Bar♦Front Strut Bar♦TL-S Rear Sway Bar♦MOOG Rear Endlinks♦HFP Suspension♦Ingalls Camber Kit
Engine/Performance
Nokya Battery Tie Down♦Spoon Radiator/Oil Cap♦Skunk2 Clutch Cover♦Stainless Brake Lines♦TL Engine Cover♦RV6 J-Pipe & Test Pipe♦Short Ram Intake
Old Oct 16, 2004 | 08:44 AM
TIM TIM TIM's Avatar
could be worse
yeah im pretty sure you do have to take it off
aim:because tim said
Old Oct 16, 2004 | 08:51 AM
FiReBReTHa's Avatar
Goodbye thanks 4 the fish
bearings and then bushings on your.....
daym.... guys im doing it again, brain fart.
"Rods" "connecting"
if these bushings break up it will casue what your describing.
04GSXR
96 Eagle Talon TSI AWD.
