Good Deal?
Old Sep 23, 2004 | 01:12 PM
Dizin's Avatar
Alive Yet Again
Default Good Deal?
Its been a long time, I dont remember how to link anymore but I wanted to get some feedback on if this kit is a good deal or not. I am sick of t25's and i and i have a big 16g. I know i need all of this stuff but would it be better to shop around for each part or just do it all at once? let me know
thanks
chris
http://dsmparts.com/customer/product...&cat=87&page=1
almost dumped 07 SI
Old Sep 23, 2004 | 01:14 PM
Ian MMF's Avatar
Omnipotence
To me that seems like alot of money. I would just shop around for all the parts and put it together that way.
Old Sep 23, 2004 | 01:16 PM
czech09's Avatar
What Mr. 4drwhore said when you gonna show me around Gainesville ?
Skillionaire's Avatar
Nobody
Definitely no need for all that. you can piece together your own kit for nearly 1/4 that price. Pick up a stainless oilfeed and J-pipe from RRE. But all the other stuff can be had much cheaper
"So...is there any tread left on the tire..or at this point would it be like throwing a hotdog down a hallway"
-Stewie (Family Guy)
Old Sep 25, 2004 | 08:29 AM
Smokey Bandit's Avatar
BOOBIES!!!!
I just went through all this myself. All you need to do is get a oil feed line and banjo bolt from any 1g turbo motor, get a plug for your oil pump line that went to the T25 (you no longer need it) or just have the line welded closed, the oil return pipe on the turbo side will need the bolt holes wider on the turbo side, j pipe from ebay or RRE (probably your 2 cheapest choices), then cut your current lower hose to act as a l pipe, and everything else should work just fine. Dont forget about your gaskets. You should be able to find them anywhere.
MODS: EVO III 16G turbo, EVO III mani, EVO III O2 housing, GReddy 24R FMIC with all piping, HKS BOV w/recirc kit, GReddy Profec B spec 2 boost controller, HKS turbo timer, Cheapy intake, APEXi N1 turbo back exhaust, B&M short shifter, Prothane motor mounts, blitz boost, oil pres. guages and autometer a/f guage.....Soon to go in JDM 6 bolt motor, 550cc injectors, 255 high pres. fuel pump, APEXi SAFC2, all sitting here waiting on some more parts to come in for the swap.
Old Sep 25, 2004 | 10:11 AM
Ian MMF's Avatar
Omnipotence
Looks like I might be needing some parts off a friends car in gainesville for the new ride so maybe sooner then was originally planned. That way I can introduce you to some people up there also.
