99 Eclipse headlight lenses all yellow. help me!
Old Aug 17, 2004 | 04:42 PM
gator's Avatar
Underdog
Default 99 Eclipse headlight lenses all yellow. help me!
i got quoted for about 200 bucks to have them buffed out and they will be clear again. i saw the price of the whole headlight assembly and it is OUTRAGIOUS prices. over 250 dollars +++ for them. i cant seem to find where i can just order the lenses. right now it is like driving around with a flash light for headlights. guess it was the heat that yellowed them.
1999 Pontiac Trans Am
Originally Posted by 1Bad00SS
What makes you think you could of keep up with me. Have you ever had that car on a dyno?
Old Aug 17, 2004 | 06:08 PM
TampaTSi's Avatar
fogged on the inside? drill a hole
messed up on the outside? use chrome polish
1998 Eclipse GST
Old Aug 17, 2004 | 10:31 PM
BoostLogik's Avatar
BoostAddict
^^^ Yes, I agree. If you can't tell if they are yellowed out from the inside or outside, try the cheapest method first. Get some "Mothers Metal Polish" and buff it into the lenses really good. It will definently take some elbow grease, but it should be able to clear them up. Let the polish haze for a bit and then wipe off with a terry cloth towel. You should be able to see the yellow transferring over onto the towel.
"Even through the darkest days, this fire burns, always"
Old Aug 17, 2004 | 10:55 PM
Skillionaire's Avatar
Nobody
brake fluid + brillo pad does headlights good
"So...is there any tread left on the tire..or at this point would it be like throwing a hotdog down a hallway"
-Stewie (Family Guy)
Old Aug 18, 2004 | 01:38 PM
Nick's Avatar
Ridin dirty
Ill do it for $50 and they will look brand new.
Brake fruid and a brillo pad then they will need to be polished.
AIM: Boost113
New best time @ Jennings 1:25.4
Old Aug 18, 2004 | 03:59 PM
gator's Avatar
Underdog
NC Boost you have a PM. thanks!
Old Aug 19, 2004 | 07:27 PM
eclipticrider's Avatar
www.2gnt.com
just fyi there is a set of 98 eclipse headlights (pair) on ebay right now for like 60 bones + s/h
they fit all models 95-99 just fine
mods:
60mm tb + the normal mods + bass + lights. well u get the picture
