boost problem
Old May 6, 2004 | 03:19 PM
str33tracer_18's Avatar
Default boost problem
i installed a 14b on my 2g and it has a burshur racing j-pipe that doesnt have the vacuum nipple on it. so i ran my mbc like it says to on hallman from t-ing off the vacuum line from the bov to the mbc and from the wg the the bc. well i tried that and flip flopped the hoses adjusted all ways poss. and no control of boost. it just goes up. so i hooked back in to the boost selenoid and still no control. anyone have any suggestions why or how to fix this. thanks.
Old May 6, 2004 | 03:48 PM
PoppaSmurf's Avatar
Chowdah-head
try running just a vacuum source without the boost controller to the wastegate, if it works, the tee in the boost controller....if you already did that, then your wastegate solenoid might be fucked up or stuck....or you have a vacuum signal thats distorted from being tee'd off too many times.....just stuff to think about
Poppa J. Smurf
Old May 6, 2004 | 03:56 PM
what do you mean just a vacuum source? and is there any wany to check the w.g. solenoid? thanks for the input.
