need to find out bolt size?
Old May 2, 2004 | 07:34 PM
str33tracer_18's Avatar
Default need to find out bolt size?
I DID A 14B install on my 2g and i used a ss oil feed line to the head like the 1g's but i need to get a bolt to block off the old line. i went a couple different places and they didnt have anything that would fit. there's like 3 different fine threads. if anyone has done this and knows or knows where to find out hich size online or something please help.
Old May 2, 2004 | 08:23 PM
Mr 2's Avatar
New Member
get a plug from another 2G. and why would you feed from the head?
Old May 3, 2004 | 03:22 AM
F4A22's Avatar
Old School
Off the subject is your t25 for sale?
Old May 3, 2004 | 08:21 AM
the 2g's dont have lugs. they have a line from the filter to the turbo. i ran a 1g set up. from the head to the turbo because the 2g oil line doesnt fit in a tdo5h. so i had to get a ss feed line for the 14b and run it to the head just like the 1g's are set up. i just need to block off the old oil feed line location.
Old May 3, 2004 | 08:22 AM
yeah it will be up for sale once i get everything worked out with the 14b. all i need to do is plug the oil line and that should be it. everything else is good but i want to make sure before i go selling anything. but the t25 is perfect and has no shaft play. i took pics.
Old May 3, 2004 | 10:54 AM
FiLjAr4LiFe's Avatar
www.myspace.com/filjar
like i said man. you need to head down to amazon hose with that end of the oil feed line and they will find or make you a plug... That's where i got mine...
Old May 3, 2004 | 11:43 AM
Mr 2's Avatar
New Member
They do have plugs on the oil filter housing at a different point.
