Question
Old Apr 20, 2004 | 05:17 PM
Redlinegvr4's Avatar
Boom Goes The Dynomite
Default Question
For a 14b install on a 2g gst can you set up the oil feed line like it is set up on a turbo 1g? You know banjo bolt that goes into the head and an oil line to the turbo? Also can you use the 1g oil feed line on a 2g if you set it up like a 1g
United States Air Force!
Old Apr 21, 2004 | 11:20 AM
FiLjAr4LiFe's Avatar
www.myspace.com/filjar
please help!
Old Apr 21, 2004 | 12:18 PM
Rich's Avatar
Old School.
Its not uncommon:
to put a 1g head on a 2g
to put a 2g manifold on a 1g
to put a 1g turbo on a 2g
to put a 1g motor in a 2g
If the hole for the banjo bolt is similiarly drilled, you should be able to assume that the orientation of the rest of the setup is identical.
You may know who we are, but we KNOW who you are.
Old Apr 21, 2004 | 03:50 PM
PoppaSmurf's Avatar
Chowdah-head
yes, you can run the oil feed off of a 2g head
Poppa J. Smurf
