throwout bearing
Old Feb 10, 2004 | 04:15 PM
cheesy's Avatar
Back on the road again...
Default throwout bearing
anyone on here know how to replace a throw out bearing on a 91 Tsi? if anyone does i am gonna need someone to do it and i would like for it to be proffesionally done. not someone tryin to learn or shit, and someone that can garuntee their work. also may need someone to do something with the head gasket. need to find out problems then will put on post.have money to pay for help.
Old Feb 11, 2004 | 07:39 AM
cali's Avatar
Skittle on crack!
I think he belongs to you guys
You can quit watching me now....
Old Feb 11, 2004 | 08:05 AM
psifactor's Avatar
Hello
pull out your wallet....to get the throwout bearing and headgasket done professionaly you are going to be 500+ easily
Heavy car with a 2.5L
Old Feb 11, 2004 | 10:09 AM
4g63's Avatar
the tob isnt a part you can just change, you must pull the tranny which will cost you at least 300 bux, do it yourself and learn a lot about your car in the process. As far as the hg goes, what makes you tink there is something wrong with it?
Old Feb 11, 2004 | 10:20 AM
cheesy's Avatar
nothing about the headgasket i heard the guy wrong. all i need to worry about right now is the throw out bearing.
TR's drive my car more than 2500 miles in less than a month crew member #01
Old Feb 11, 2004 | 10:29 AM
Skillionaire's Avatar
Nobody
I you are still running the stock clutch, id highly recommend you upgrade. Changing the TOB is practically doing a clutch job. Might as well save on labor twice
"So...is there any tread left on the tire..or at this point would it be like throwing a hotdog down a hallway"
-Stewie (Family Guy)
Old Feb 11, 2004 | 01:03 PM
4g63's Avatar
for real
Old Feb 11, 2004 | 01:39 PM
91TSI_AWD's Avatar
Resident Galant Guy
I will change your Throw out bearing for 300. If you want to get an aftermarket clutch at the same time i will put that in at the same time for no extra charge. Let me know. I am in Bradenton and will need a couple days, if you want to get your flywheel cut. Also is this TSi AWD or FWD?
Mike
95 Lancer GSR
93 300ZX 2+2
Old Feb 11, 2004 | 03:17 PM
cheesy's Avatar
https://www.tamparacing.com/forums/s...hreadid=128782 its this car. has a fly wheel and clutch so all i need it to do the bearing. yea 300 sounds good
i wont have that much for a little while but give me your # 91TSI AWD and i will keep it available and give you a call when i have the part and money for you to do it.
