Greddy Type S
Old Feb 1, 2004 | 08:42 PM
FiLjAr4LiFe's Avatar
www.myspace.com/filjar
Default Greddy Type S
Hey i installed my greddy type s with a flanged upper intercooler piping. im pretty sur ei have everything connected right and shit. But it cant be because when i drive it, in some gears it will not accelerate anymore and it will make a kinda horn honkling noise. My guess is somthing is bleeding...
I have my stock airbox in. And with that upper intercooler piping i could only get 1 of 3 screws that connect to the airbox in. My final guess about what is wrong is that that box needs to be completely screwed down because its not able to suck enough air through the air box? i dont know man. Could anybody help me out please?
Thanks in advance.
Old Feb 2, 2004 | 07:00 AM
Skillionaire's Avatar
Nobody
BOV adjustment screw is possibly too lose causing a boost leak. or you may have a leak somewhere else.
"So...is there any tread left on the tire..or at this point would it be like throwing a hotdog down a hallway"
-Stewie (Family Guy)
Old Feb 2, 2004 | 11:24 AM
REDchirp's Avatar
Blown 7thgen... Literally
Thats what i was thinkin... when i read ur post... i think u might have a boost leak aaron... check it out... and please... get the screws in... u were missing a key one on the valve cover the other day... and thats why the oil was all over the top of your valve cover... u might wanna check ur oil now too... cause u were pushing a lotta smoke out back today... JMO
Old Feb 2, 2004 | 12:20 PM
97gstblack's Avatar
u have the gasket right(for the greddy vavle)? if u dont go get one, and get rid of that dam airbox.....a hornhonking hmmm that doesnt sound like a boost leak. also oil will come out of the shitty plastic oil caps, best to go get another one at advance or something. but yes also test for leaks cause they can do some funky stuff, that leak could be y you can accellerate anymore.
'D'ont 'S'tart 'M'oding
Old Feb 2, 2004 | 05:00 PM
Im pretty sure thats it. The gasket thing. Where can i get a greddy type s gasket? Can i just hit up discount autoparts and grab that flat gasket cut out shit and glue it on the flange or the bov?
Lemme know. Im pretty sure its a leak between flange and BOV.
Old Feb 2, 2004 | 05:41 PM
Ender.'s Avatar
Eis Aner Oudeis Aner
aaron if you want to come over tommorow I can try and help you out. Ill be doing a brake pad job for a friend so if you want just stop by.
Old Feb 2, 2004 | 06:56 PM
aight dude. I uhhh think i can handle putting a gasket in though . The only thing i could possibly need help with is the gauges cause i dont know how to tap into the ecu to hook up a/f guage.
Old Feb 3, 2004 | 01:32 PM
97gstblack's Avatar
yes u can get one from auto that cut out one should be fine.
Old Feb 3, 2004 | 04:30 PM
Thanks for all the help guys. The cut out gasket works great. Vented to the atmosphere runs perfect. Thanks.
