Technical Question
Old Jan 16, 2004 | 10:34 AM
hunntyr's Avatar
Question Technical Question
Hey guys....I have a question about my engine. When I begin to accelerate there seems to be a very light rattling coming from it. Nothing big and I have only noticed it in the Mornings when I start it and at night lately when its colder. During the day when I drive, there's no noise or any other problems at all. The best way I can describe it is like shaking up loose change in a can but again its not loud. Could I have possibly spun a bearing or do you think it could be something else??
Old Jan 16, 2004 | 10:42 AM
Ep41382's Avatar
TR Balla Donor Supreme
does it only happen when you start the car? if so its probably the starter. Thats my guess. Mine used to make a weird noise like that when it would start up.
Eric
AIM: Ep41382
Old Jan 16, 2004 | 11:09 AM
hunntyr's Avatar
its not the starter.....its actually while the car is running
Old Jan 16, 2004 | 02:19 PM
Nick's Avatar
Ridin dirty
Its hard to tell when your not there to hear it first hand.
AIM: Boost113
New best time @ Jennings 1:25.4
Old Jan 16, 2004 | 02:31 PM
hunntyr's Avatar
ok well picture this if you can. Take a few dimes and attach them to a string and drag across the concrete gently. It is happening when I rev between 2 and 2.5k rpm's. If I run harder, sound is gone. I think it could be a spun bearing or maybe a ring going bad but I kinda would a 2nd opinion.
Old Jan 16, 2004 | 02:55 PM
4g63's Avatar
what is your motor mount/clutch setup?
Old Jan 17, 2004 | 07:00 AM
hunntyr's Avatar
its a stock 420a with a 7 bolt
Old Jan 17, 2004 | 07:10 AM
Ender.'s Avatar
Eis Aner Oudeis Aner
This is just a thought, if you have a heat shield try tightening it down more. Mine would rattle only at a certain RPM kind of like what your describing.
Old Jan 17, 2004 | 09:44 AM
hunntyr's Avatar
Actually I took the heat shield off a long time ago cause it was all rusted and nasty. Also I was preparing to do some work on the exhaust mani for when I got my turbo so that isnt the problem. It sounds like its coming from inside the head but I cant tell if its in the head or further down in the block. I have a pretty good feeling that its the rings because I am also burning oil again. What do you guys think???
