Installing Boost/A/fGauge
Old Jan 10, 2004 | 07:45 AM
FiLjAr4LiFe's Avatar
www.myspace.com/filjar
Default Installing Boost/A/fGauge
Ok i have them in a pillar. Ive already connected them to the sunroof wire thingy. And grounded it on the screw down by the fuse box. I routed the vacuum hose and the wire that goes to the o2 sensordown near the fuse box. Is there a hole where i can feed the vacuum hose and the wire to the o2 sensor into the engine area so i can umm hook them up lol?
Old Jan 10, 2004 | 07:47 AM
4g63's Avatar
I cut a small slit in the steering boot and fed them thru there.
str33tracer_18's Avatar
there is a black boot 5"x 5" where i think its the steering goes through.ive seen people drill small hole into one side of this and fed it threw.
Old Jan 10, 2004 | 07:52 AM
The guy that i got the gauges from said there was a hole that yo uwould feed it through without drilling.
Anybody know of this hole?
Old Jan 10, 2004 | 08:37 AM
Skillionaire's Avatar
Nobody
Use the steering boot hole. Just cut a small slit in it with a box cutter or some other blade.
"So...is there any tread left on the tire..or at this point would it be like throwing a hotdog down a hallway"
-Stewie (Family Guy)
Old Jan 10, 2004 | 01:28 PM
97gstblack's Avatar
steering boot is best..
'D'ont 'S'tart 'M'oding
Old Jan 11, 2004 | 07:55 AM
Thanks a lot guys.
Old Jan 11, 2004 | 10:51 AM
eclipsegst303's Avatar
.:DSM:.
ummmm, that af gauge wire doesnt go into the engine bay, it goes to the ECU's o2 sensor wire INSIDE the car......
Old Jan 11, 2004 | 11:02 AM
Nobody
Good call...i didnt even catch that. Yeah, the only thing that needs to go through is the nylon tubing for the boost gauge.
