? on problem
Old Dec 21, 2003 | 05:25 PM
str33tracer_18's Avatar
Default ? on problem
i have a 95gst.when it idles sometimes it idles up and down.probably the iac.i took it to the mitsu. dealership and they said it need a new t/b.i ordered one but havent got it yet.i hear that the iac goes out in these alot.anyone had this prob?also when i drive and am in say 4th gear at 50mph and stomp on it it studders reeeaaal bad.is this normal because the turbo isnt spooled up yet?this is my first turbo car and ive never even riden in a turbo car before this so im lost.i just bought the car and need to get it running good so i dont feel i got ripped off.please help.thanks>
Old Dec 21, 2003 | 07:18 PM
psifactor's Avatar
Hello
DAMN....That was annoying! Learn to use spaces in between your sentences.
My ecu seems to react better to gradual throttle and does not like quick "stomps", but every dsm is different. I doubt its lag.......
You can also find a 1g throttle body elbow to throw on there, instead of paying a dealer hundreds of dollars. 1g throttle body>2g throttle body.
Being a 95 that you just purchased...with adverage milage would put it around 100k, or so. Just do a tune up on the whole car and that will also rule out alot of other possibilities.
Heavy car with a 2.5L
Old Dec 22, 2003 | 02:32 PM
slowy's Avatar
13.04@104mph
tune ups work wonders
NGKbpr7es = part # 2023 at Advance/Discount Auto Parts
Old Dec 22, 2003 | 03:37 PM
Mr 2's Avatar
New Member
what the fuck is a tune up? i keep hearing that phrase and it make no sence to me.
Old Dec 22, 2003 | 03:53 PM
Tom N's Avatar
Non DSM.....DSM guy
I believe thats a upgraded BOV and a turbo timer.
Tom
Old Dec 22, 2003 | 07:24 PM
Mr 2's Avatar
New Member
BTW unless you are making 400hp, I do not recomend putting BPR7ES spark plugs in. I always ran slower with them when I had the 16G and they fouled to much. BPR6ES is just fine for a 300hp or less car.
Colder plugs DO NOT increase spark or power, all they do is cool off faster which can help a bit if you have alot of knock or are tunning on the edge. Because they stay cooler they may not burn all the deposits off causing them to foul and you will then LOSE power.
If you have less than 400hp and are knocking alot fix your problem, lower your timming or increase fuel, plugs aren't a mod.
Old Dec 22, 2003 | 07:32 PM
slowy's Avatar
13.04@104mph
tune up man,,DUH ! 5extra psi in the tires, fill up the washer fluid, ya know,, that kinda shit..plugs are too a mod! Denso Iridium's give you +15hp,, it says so on the box, lol jfwy
i didnt know that about the plugs, ill try the 6's and see what happens, u happen to know the part number off hand?
Old Dec 22, 2003 | 07:54 PM
Mr 2's Avatar
New Member
BPR6ES
Let me clarify a little more...
Colder plugs simply have more ceramic material (white part around the electrode) touching the outside housing (metal part with threads) of the plug. The ceramic part is there to insulate the electrode from the casing (which is grounded) and as we are discussing to pull heat from the hot electrode (heatsink affect). Your plugs need to stay at certain temps to stay clean, if they are not hot enough the plugs will build up with carbon (fouling).
So the BPR6ES’s are the same plugs as the BPR7ES except the BRP7ES’s have slightly more ceramic insulating material.
How do colder plug help?
Detonation can be spawned by hot spots in the combustion chamber. If your cylinder temps get really hot your plugs will get hotter, if the insulator does not pull enough heat from the electrode it will become a hotspot that may cause detonation.
Old Dec 22, 2003 | 07:55 PM
Mr 2's Avatar
New Member
you simply need to match the right plug heat range with your engine. With low powered DSMs the 6s seem to be perfect.
Old Dec 22, 2003 | 08:13 PM
ChrisMonsod's Avatar
Drives a cowboy corvette
bobby its chris.. i know a lil about turbos ...
give me a call ..
727-364-9266
