MBC question
Old Nov 5, 2003 | 10:37 AM
EclipseRSTurbo's Avatar
Default MBC question
hey guys, i just bought a SBR manual boost controller and i was just wondering if i would be able to turn my boost up to about 6 psi with the MBC, i have a boosted 420A with a HRC stage 2 kit,.............am i gonna need to turn the fuel pressure up also?
Ya its an RS-T. they only make them in Japan
Old Nov 5, 2003 | 10:59 AM
Chris LS's Avatar
just blaze...
Im thinking, that you wouldn't need to since its only 6 psi, but im not sure...
Quote : I'm Slow:
Less hours = less $$. Less repetitive 'ish every day = PRICELESS!
Old Nov 5, 2003 | 11:04 AM
Skillionaire's Avatar
Nobody
If your wategate is set to less than 6psi, then yes you can set the MBC to 6 psi. Are you running a direct line from boost source to WG right now? How much boost is that yielding? If its over 6psi, a MBC wont allow you to lower it.
"So...is there any tread left on the tire..or at this point would it be like throwing a hotdog down a hallway"
-Stewie (Family Guy)
Old Nov 5, 2003 | 11:20 AM
umm im not sure, all i know is that, all i know is that i have a 5 psi acuator on there now, and i am only running about 3 psi cause the FMIC
Old Nov 5, 2003 | 11:28 AM
Jordan Y.'s Avatar
15 seconds EXHILARATION
Like skillionaire said, as long as your boost is lower than 6 psi off the wastegate, throwing an mbc into the connection with the actuator will let you raise it to 6.
Old Nov 5, 2003 | 11:32 AM
alright thanks, but how would i connect it?
Old Nov 5, 2003 | 11:56 AM
Nobody
Basically the MBC is gonna "T" into the line you currently have going to your Wastegate.
Old Nov 5, 2003 | 02:38 PM
BoostedRS's Avatar
I can freeze time
Default Re: MBC question
Depends in what fuel pressures you are running now, I believe at 8-9 psi, you gotta have like 110-120 psi, check the HRC manual and it'll tell you. Just a rule of thumb, more power = more air (higher boost) = more fuel needed.
Olympus Evolt E-510, E-520, E-30 x 2
11-22mm f/2.8-3.5 Zuiko Digital
14-54mm f/2.8-3.5 Zuiko Digital
35-100mm f/2 Zuiko Digital
50-200mm f/2.8-3.5 ED SWD Zuiko Digital
Cybersync wireless trigger
FL-36R, FL-50R, Metz-48, and Vivitar 285HV x 3
Old Nov 7, 2003 | 09:39 AM
420aTurbo's Avatar
DSM Pimp
You can run up to 8-9 psi on the stock 420a injectors. If you have the stage 2 HRC kit with FMIC than 8-9 psi will be no problem.
