Throttle Body FOR 2.0 TURBO
Old Jul 21, 2003 | 07:33 PM
seventhgear's Avatar
hanglike sleeve of wizard
Default Throttle Body FOR 2.0 TURBO
ok i need an eclipse TB 65mm or bigger ... post or pm me with prices and brands stating what diameter the TB is
thanks
jack
image removed from your sig...see forum rules
Old Jul 21, 2003 | 11:26 PM
KillahB's Avatar
Stock 2G Eclipse TB is 52 mm and the stock 1G is 60mm. If you want 65mm, I think the twin turbo 3000GTs are that big stock, yo u can try those. I think they have some weird ISCs tho, so good luck.
4G93 1/2 T - down for now
4G69 - daily
Old Jul 22, 2003 | 07:14 AM
thanks man !
Old Jul 22, 2003 | 08:12 AM
PoppaSmurf's Avatar
Chowdah-head
use a custom intake and get like a 75 mm bbk throttle body, it'll work out much better than trying to play with the stock throttle body
Poppa J. Smurf
Old Jul 22, 2003 | 08:31 AM
OK WELL I THINK THEY HAVE a cyclone intake from japan that they are messin with..... but im not too sure but i dont know why hes looking for a big tb... it may not be for his car .... but 65mm+ is what he told me.
jack
Old Jul 22, 2003 | 09:25 AM
PoppaSmurf's Avatar
Chowdah-head
jack
cool, i see...the cyclone intake is an interesting creature, it is sort of setup liek an integra gsr with the 2 runner setup, it is functional as long as you get the vacuum system setup right, it'll make some more low end torque, a factory USDM 1G intake is a little bit better as far as flow is concerned...but back on topic, a 1G (cyclone or USDM) throttle body, to my recollection, can be bored out to 64 mm, after that, you are looking for a new throttle body, hope this helps
Poppa J. Smurf
