MSD 6BTM Ignition Control Module w/ boost control knob
Old May 19, 2005 | 12:41 PM
aj187's Avatar
FORE:exalt
Default MSD 6BTM Ignition Control Module w/ boost control knob
brand new still in box! $400 o.b.o
Product Description:
Supercharged or turbo engines will benefit from the 6BTM in more ways than one. Not only do the full energy sparks help burn the fuel mixture, it allows the driver to retard the ignition timing based on the amount of boost being produced by the supercharger. The timing is adjusted from a dash
mounted knob and can be retarded 1 - 3° per pound of boost with a maximum of 15°. There is also a built-in adjustable rev control to protect the engine from over-rev damage.
Specifications:
OPERATING SPECIFICATIONS Operating Voltage: +10-18 VDC Negative Ground Current Requirements: 5 Amps-5,000 RPM 10 Amps-10,000 RPM RPM Range: 15,000 RPM with 14.4 Volts Spark Duration: 20° Crankshaft Rotation Energy Output Max: 105-115 mJ Per Spark Weight and Size: 3 lbs, 8"Lx4"Wx2.25"H Voltage Output Max: Primary: 460-480 Volts Secondary: 45,000 Volts (Blaster Coil)
Additional Information:
Performance Benefits:
Improves power, quickens throttle response.
Smooths out idle and starting.
Reduces spark plug fouling.
Improves mileage and reduces emissions.
CARB approved under E.O. D-40-17 for installation in all states.
File Type: bmp
[url]
69 Buick Skylark - Brokeded
91 CRX hf (zc dohc swapped) - wrecked/fixed-wrecked/fixed-wrecked-sold
91 Civic hatch (stock) - Sold
91 CRX hf (ls swapped) - Traded
90 Civic Hatch (mini me) - Sold
91 CRX si (zc dohc swapped) - Brokeded
02 Dodge Ram - gave to repo man
06 gsxr 600 - Wrecked
95 cbr f3 (stunta) - Sold
96 Integra ls - Sold
94 Integra ls - Sold
02 Dodge Ram - Daily
Old May 22, 2005 | 10:56 AM
aj187's Avatar
FORE:exalt
Ttt
[url]
Old May 31, 2005 | 08:39 AM
aj187's Avatar
FORE:exalt
Ttt
[url]
Old Jun 10, 2005 | 08:04 AM
aj187's Avatar
FORE:exalt
taking any offers. need to sell!
[url]
Old Jul 29, 2005 | 12:34 PM
aj187's Avatar
FORE:exalt
ttt 250
[url]
Old Aug 1, 2005 | 06:32 AM
aj187's Avatar
FORE:exalt
[url]
