Where is the tech in mazda tech forum
Re: Where is the tech in mazda tech forum
This is for Mazdas,not a "lounge" for any vehicle or any topic.
So keep this Mazda related or ill bann your ass
Yeah there isnt much "techinical" questions here....
I wonder why..
I got one for you guys..how the hell do you take the oil metering pump shaft and gear out?I been messing with mine today,and want to take it out before I bust out the die grinder..
go FAQ urself . . .
on
is everything apart? I took mine apart, I forget how I took everything out. I just remember disassembling everything. Mine still leaks oil though. I think I need new gaskets?
it doesnt say how to disassemble it in the manual???
are you just planning on running premix or what? I run premix but i left my shizzle on for back-up.
go FAQ urself . . .
on
That is what I did. No engine oil in my combustion chambers. Pre mix is made to burn and doesnt leave the deposit regular oil will. I mix 3.5 oz to 5 gal. I heard of people running 1oz to 1 gal, but when I was running the rich mix seemed like it didnt run as well as the 3.5 per 5 gal, which is what Racing Beat suggest.
Anyways..Update*
Its out... im polishing the front cover and the block off plate is nice..
Yes I will be premixing..So I know I will be getting a good amount of oil to the seals,plus no OMP= no oil leaks..
When they leak..You have to buy a rebuild kit..and I only seen one place online that sells a OMP rebuild kit its like 10.-15.$ but I took it out for less problems..
Im still running the beehive oil coover but it will look nice when im done with it..Fuck it..
