rear end ratio
Old Jun 8, 2009 | 10:21 AM
prican's Avatar
Default rear end ratio
I have a project that im working on:
https://www.tamparacing.com/forums/m...3-project.html
it has a ford 9 inch rear end what is a good gear ratio to go with keeping in mind that i do not want to go 70-80mph in hwy and redline in 5th gear i have a 3.25 now
thanks for the help
R.A.P.S member number #0006
Rotaries
Against
Piston
Swaps
msn: prican8069
yahoo: ltorovelez
aim: ltorovelez
Old Jun 19, 2009 | 08:57 AM
landon303's Avatar
Velocity (ft/s) = (rpm of engine x TIRE radius x 2 x 3.14)/(dif ratio x ratio for 5th gear x 60 sec/min) so just make your dif ratio "x", solve, using what the ratio of your current transmissions 5th gear is, and how fast you want to be going at that RPM. Remeber its in ft/s for velocity. pro tip: 60mph = 88ft/s. if you are clueless about your 5th gear ratio, MAZDATRIX for Mazda RX7, RX8, Rotary Engine Parts and Accessories has a great layout of OEM transmission & dif ratios for the 1979-1995 american RX-7
engine, not motor
Old Jun 19, 2009 | 09:25 AM
Brownsound's Avatar
Dude.. thats awesome.
aaaand GO!
Old Jun 19, 2009 | 06:57 PM
prican's Avatar
thanks for the great info
Rotaries
Against
Piston
Swaps
msn: prican8069
yahoo: ltorovelez
aim: ltorovelez
